How do I change (Admin) StoreManager image in PS 4.5?
I would like to customize the Administration section of a store.
Where is the line of code located for changing the Store Manager image - adminlogo.png?
PowerStore 4.5
PowerStore 4.5
You will find that in the following location:
webassist/themes/Default/templates/admin.dwt.php
Hi
the graphic is called by over 34 files
the path to the graphic is
<img src="images/adminlogo.png" />
So you can either rename your graphic to adminlogo.png or do a find and replace on adminlogo.png
You also could try editing this tdreamweaver template if you have Dreamweaver
webassist\themes\Default\templates\admin.dwt.php
HTH
Ian
Thank you guys for the info.
Renaming the NEW graphic adminlogo.png and the old graphic adminlogoOLD.png worked perfect. All pages were updated.
Dan
