Thanks Jason
It's v4.?? at the moment - we will be upgrading shortly.
Following code:
error_reporting(E_ALL);
<?php require_once('Connections/connRIBIT.php');?>
<?php require_once("webassist/form_validations/wavt_scripts_php.php"); ?>
<?php require_once("webassist/form_validations/wavt_validatedform_php.php"); ?>
<?php require_once( "webassist/security_assist/helper_php.php" ); ?>
if (isset($_POST["ForgotPassword_submit"])) {
$WAFV_Redirect = "".(htmlentities($_SERVER["PHP_SELF"], ENT_QUOTES)) ."?invalid=true";
$_SESSION['WAVT_forgotpassword_Errors'] = "";
if ($WAFV_Redirect == "") {
$WAFV_Redirect = $_SERVER["PHP_SELF"];
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateEM((isset($_POST["Forgot_Password_group_MemEmail"])?$_POST["Forgot_Password_group_MemEmail"]:"") . "",false,1);
if ($WAFV_Errors != "") {
PostResult($WAFV_Redirect,$WAFV_Errors,"forgotpassword");
function WA_SecurityAssist_Email_1_SendMail($WA_Auth_Parameter){
$WA_MailObject = WA_SecurityAssist_Definition("smtp.domain.org","25","","","");
$WA_MailObject = WA_SecurityAssist_SendMail($WA_MailObject,"","","",$WA_Auth_Parameter["toAddress"],"",$WA_Auth_Parameter["fromAddress"],$WA_Auth_Parameter["subject"],$WA_Auth_Parameter["mailBody"]);
$WA_MailObject = null;
}// WA_SecurityAssist_Email_1_SendMail
if(isset($_POST["ForgotPassword_submit"])){
//WA SecurityAssist Email object="mail"
$WA_Auth_Parameter = array(
"connection" => $connRIBIT,
"database" => $database_connRIBIT,
"tableName" => "rotarians",
"filterColumn" => "MemEmail",
"filterEncryption" => "",
"columnValue" => "".((isset($_POST["Forgot_Password_group_MemEmail"]))?$_POST["Forgot_Password_group_MemEmail"]:"") ."",
"columnType" => "text",
"usernameColumn" => "MemUserName",
"usernameEncryption" => "",
"passwordColumn" => "MemPwd",
"passwordEncryption" => "",
"selectColumns" => array("MemUserName","MemPwd","MemEmail"),
"sessionVariables" => array(""),
"successRedirect" => "clublogin.php?emailedPassword=1",
"failRedirect" => "forgotpassword.php?notFound=1",
"keepQueryString" => TRUE,
"toAddressColumn" => "MemEmail",
"toAddressEncryption" => "",
"fromAddress" => "sysadmin@domain.org",
"fromAddressDisplay" => "",
"subject" => "forgotten login details",
"mailBody" => "webassist/security_assist/email/forgotpassword_email.php",
"emailFunction" => "WA_SecurityAssist_Email_1_SendMail"
WA_Auth_ForgotPassword($WA_Auth_Parameter);
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"
"http://www.w3.org/TR/html4/loose.dtd">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<title>Forgotten login details</title>
<script src="webassist/progress_bar/jquery-blockui-formprocessing.js" type="text/javascript"></script>
<link href="SpryAssets/SpryValidationTextField.css" rel="stylesheet" type="text/css">
<script src="SpryAssets/SpryValidationTextField.js" type="text/javascript"></script>
<script src="webassist/forms/wa_servervalidation.js" type="text/javascript"></script>
<link href="webassist/forms/fd_basic_default.css" rel="stylesheet" type="text/css">
</head>
<body>
<?php if(WA_Auth_RulePasses("Validated form")){ // Begin Show Region ?>
<p>Invalid information, please check your entries and try again</p>
<?php } // End Show Region ?>
<?php if(WA_Auth_RulePasses("Email address not found")){ // Begin Show Region ?>
<p>Your email address could not be found in our records. Please try again.</p>
<div id="ForgotPWContainer" class="WAATK">
<div id="ForgotPassword_Basic_Default_ProgressWrapper">
<form class="Basic_Default" id="ForgotPassword_Basic_Default" name="ForgotPassword_Basic_Default" method="post" action="<?php echo (htmlentities($_SERVER["PHP_SELF"], ENT_QUOTES)); ?>">
WebAssist CSS Form Builder - Form v1
CC: Forgot Password
CP: Default
TC: Basic
TP: Default
<fieldset class="Basic_Default" id="Forgot_Password">
<legend class="groupHeader">Forgotten login details</legend>
<span class="fieldsetDescription"> Required * </span>
<div class="lineGroup">
<label for="Forgot_Password_group_MemEmail" class="sublabel" > Your Email address:</label>
<div class="errorGroup"> <span id="Forgot_Password_group_MemEmail_Spry">
<input id="Forgot_Password_group_MemEmail" name="Forgot_Password_group_MemEmail" type="text" value="<?php echo((isset($_GET["invalid"])?ValidatedField("forgotpassword","Forgot_Password_group_MemEmail"):"")); ?>" class="formTextfield_Medium" tabindex="1" onBlur="hideServerError('Forgot_Password_group_MemEmail_ServerError');">
if (ValidatedField('forgotpassword','forgotpassword')) {
if ((strpos((",".ValidatedField("forgotpassword","forgotpassword").","), "," . "1" . ",") !== false || "1" == "")) {
if (!(false)) {
<span class="serverInvalidState" id="Forgot_Password_group_MemEmail_ServerError">Please enter a value.</span>
<?php //WAFV_Conditional forgotpassword.php forgotpassword(1:)
<span class="textfieldInvalidFormatMsg">Invalid format.</span><span class="textfieldRequiredMsg">Please enter a value.</span> </span> </div>
</div>
<span class="buttonFieldGroup" >
<input class="formButton" name="ForgotPassword_submit" type="submit" id="ForgotPassword_submit" value="Send" onClick="clearAllServerErrors('ForgotPassword_Basic_Default')" tabindex="1">
</span>
</fieldset>
</form>
</div>
<div id="ForgotPassword_Basic_Default_ProgressMessageWrapper" class="blockUIOverlay" style="display:none;">
WADFP_SetProgressToForm('ForgotPassword_Basic_Default', 'ForgotPassword_Basic_Default_ProgressMessageWrapper', WADFP_Theme_Options['BigSpin:Slate']);
</script>
<div id="ForgotPassword_Basic_Default_ProgressMessage" >
<p style="margin:10px; padding:5px;" ><img src="webassist/progress_bar/images/slate-largespin.gif" alt="" title="" style="vertical-align:middle;" /> Please wait</p>
</div>
</div>
</div>
var Forgot_Password_group_MemEmail_Spry = new Spry.Widget.ValidationTextField("Forgot_Password_group_MemEmail_Spry", "email", { isRequired:false , validateOn:["blur"]});
</script>
</body>
</html>
Cheers
Chris
