SQL syntax error
Thread began 10/14/2011 3:59 pm by jvorzimer358609 | Last modified 1/12/2017 10:15 pm by Ray Borduin | 3661 views | 25 replies |
jvorzimer358609
SQL syntax error
When I tried testing the cart I built I made it through getting the item into the cart and the checkout page but when I then click on Checkout button I get the following parsing error when it tries to address the confirm.php page:
Parse error: syntax error, unexpected '@' in /homepages/46/d366494719/htdocs/myoscript3/pages/confirm.php on line 155
On line 155 there is a vraiable set without parentheses:
$WA_fieldValuesStr = @@FieldValueStrParam@@;
There is another lne that DreamWeaver flags as having a syntax problem at line 186:
I put the parentheses in on both of these lines and the parsing error stopped but then I got the following SQL syntax error:
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '@@FieldNameStrParam@@) values (@@ColumnTypeStrParam@@@@FieldValueStrParam@@@@Col' at line 1
jvorzimer358609
I went back through and completely rebuilt the cart and checkout pages and still get the same errors coming up.
phillipcox143131
Database Problems
Hi im haveing the same issues
I can run the script direct from the db file but when installing get all the errors going 2 examples below. The frustrating thing is that everytime it goes wrong i have to copy the files over again as they have been altered as part of the install
AAAhhhhh
ERROR: Database could not be created.
'?CREATE TABLE IF NOT EXISTS `ps4_categories` ( `CategoryID` int(11) NOT NUL' at line 1
MySQL server version for the right syntax to use near '?CREATE TABLE IF NOT EXISTS
ERROR: The ceda database is not empty, it already contains tables named ps4_categories,
ps4_contenthistory, ps4_contents, ps4_couponproducts, ps4_coupons, ps4_optiongroups,
ps4_options, ps4_orderdetails, ps4_orders, ps4_productcategories, ps4_productoptions,
ps4_products, ps4_simpleoptions, ps4_usergroups, ps4_users. Please create an empty
database for PowerStore to use.
mycalidesigns
I have the same problem?
Please provide more details, there are a couple different problems in this thread.
mycalidesigns
What version of eCart are you using?
Make sure you have the latest version installed.
mycalidesigns
i do. I have 6.0.7 its on my mac.
