location marker info window repeat region
Thread begun 10/12/2011 6:54 am by asnw0764437428 | Last modified 3/07/2016 11:57 am by Ray Borduin | 3594 views | 4 replies |
asnw0764437428
I am developing a new property website. All the features and map etc are all in place to show properties.
However some properties for sale are on the same street but the location marker info window will only show 1 property.
For example, say there are 10 properties for sale and 2 of those properties are on the same street. Correctly only 9 markers will show up on the map. When you click on the marker that has 2 properties it will only show 1 property and not the 2 available.
How can I implement the repeat region code within the location marker info window?
the info window does not support repeat regions.
the 2 markers will be on the page, but the user will need to zoom in to be able to see the second one.
another way of doing this would be to add a link for each address, the "How to change which address your map centers on" tutorial on the pro maps support page goes through accomplishing this:
pro-maps-for-google/
asnw0764437428
Promaps Repeat Region
Thanks for the reply, tried reading the 'How To' PDF but for some reason this error messages appears regarding missing embedded fonts within the pdf:
Cannot extract the embedded font KBFOHI+Verdana Some characters may not display or print correctly.
Any chance this can be updated, thanks.
that error should not prevent you from viewing the PDF, Reader should use the default font instead of the embedded font, there should not be any special characters in the PDF that would not be available to the default font.
what version of Acrobat are you using, make sure to have the most up to date acrobat version.
anonymous
Hi, asnw0764437428.
Thanks for sharing your problem. As for me, I have seldom tried to deal with that kind of problem before. Have you ever worked it out? I wonder whether you have any exprience about pdf extracting process. Because there is something wrong with my pdf reader. I need convert pdf into text or other formats. Any suggestion will be appreciated. Thanks in advance.
Best regards,
Pan
