Javascript error
Thread began 9/18/2011 1:59 am by theo.twisk429002 | Last modified 9/20/2011 12:38 pm by Jason Byrnes | 3720 views | 6 replies |
theo.twisk429002
Javascript error
After setting up a site and creating a template (with editable regions for content, menu and footer) I wanted to use theme-it but got the following error message:
while executing onLoad in wa_themeit.htm the following Javascript error occurred: at line 328 of file ...\wa_themeit.js: imageURL has no properties.
Delete the Dreamweaver Cache file from the users configuration folder:
theo.t429002
Problem persists
I deleted the WinFileCache.dat file (by the way: in Common Installation Issues deleting this file is restricted to CS4. I use CS5 but assumed after your suggestion to delete the cache file that this also goes for CS5) but get the same error message.
PS already uninstalled and reinstalled Theme-it
theo.t429002
theo.t429002
Has anybody from WebAssist read my message that same problem still persists
Since my reply that your "solution" did not have the desired effect and that the same Javascript error persists I have had no further reaction. I have even sent a quick reply later on but still no reaction.
theo.t429002
Solution to javascript error in Common Installation Issue no real solution
I have uninstalled en reinstalled all CSS Design suite extensions: directly after activation of Theme-it same Javascript error message
At that time there was no WinFileCache.dat file
I have tried theme-it with new CS5 layout files: sometimes theme-it starts without a problem, sometimes it starts with the javascript error
I have tried it with html files and dwt files: sometimes theme it works sometimes javascript error.
I have tried theme-it after creating a CSS Sculptor page and it worked without a problem. After that the WinFileCache.dat file was back again. When I launched Dreamweaver and saved a new html file (based on a CS5 layout) I again got the javascript error.
My impression is that theme it works with pages created with CSS Sculptor (allthough I am not 100% certain that it always works in that particular situation), but that theme it is unstable with pages created bases on CS5 layout.
The solution provided in Common Installation Issues (deleting the cache file) is not a satisfactory solution: it would require deleting the cache file everytime and even then I have noticed that in the absence of the cache file the javascript problem can still pop up. So I would really like to hear about a structural solution.
