More than 700 older files?
Thread began 9/12/2011 6:50 am by theo.twisk429002 | Last modified 9/12/2011 11:03 am by Jason Byrnes | 396 views | 1 replies |
theo.twisk429002
When I installed Site Sculptor Adobe Extension Manager gave the message that I already had a newer version of a file and asked me if I wanted to keep the newer version. So I chose to: yes.
Immediately I got the same message for another file. And so on for more then 700 files. This problem repeated itself for the other CSS Design Suite extensions that I installed: because I preferred keeping the newer file versions I had to choose No some 3500 times!!
It seems to me that it would be much more efficient if Webassist update these files before selling the software. Because I only installed one Webassist extension before (= Button styler; which was recently introduced) I assume that the newer file versions belong to Button Styler. If my assumption is correct my suggestion would be that Webassist uses the Button styler files to update the files in the other extensions.
when installing the extension, you will get the message about newer files, these newer files are the support graphic images for the User Interfaces and other common files between the extensions that dont change.
It is recommended to answer this question as yes to all.
