multiple dynamic coupon codes
I have a dynamic coupon code set up that works great. My question is this. Is it possible to use multiple coupons? In other words, how would I go about creating a cart that would accept many different coupon codes?
eyoung296270,
I have the same setup with about 6 different coupon codes!
What you do is follow the proceedure that you did for the first coupon as many times as require....just adding the new details as a new coupon. I'm not at my desk computer so I can't give you the steps and my memory isn't that good. But it can be done with ease.
As I'm not a developer I think from memory I just followed the instructions WA give for setting up one and repeated them as a new coupon for each different one I needed.
Hope this helps
James
I'm curious if I would be able to use the same discount code in eCart and use multiple recordsets based on the new coupon so that all I am adding is recordsets?
