Power CMS will not install
Thread began 8/09/2011 11:13 pm by info271221 | Last modified 8/10/2011 1:21 pm by Jason Byrnes | 811 views | 3 replies |
info271221
When you click on this link: index.php
You should be able to get to a page where you can enter a serial #. Serial.php
I am getting stuck on database.php or serial.php and nothing available on the page in the live view or view source.
I have published files and added permissions to folders.
there must be a php error occurring, but error reporting is turned off.
add the following code at line 1 of the install_cms/database.php to turn error reporting on:
error
(E_ALL);
info271221
The error reporting is not working either. Start over?
The error reporting is not working. Should I delete the database files and files on the server and just start over?
serial.zip
