Show products where status = 10
Thread began 6/28/2011 9:27 am by info271221 | Last modified 6/29/2011 1:47 pm by Jason Byrnes | 1069 views | 2 replies |
info271221
I need to show only products where status is NOT 10 and then created a similiar SQL where status = 10.
$maxRows_WADAproducts = 100;
$pageNum_WADAproducts = 0;
if (isset($_GET['pageNum_WADAproducts'])) {
$pageNum_WADAproducts = $_GET['pageNum_WADAproducts'];
$startRow_WADAproducts = $pageNum_WADAproducts * $maxRows_WADAproducts;
$IDParam_WADAproducts = "1";
if (isset($_GET['ProductID'])) {
$IDParam_WADAproducts = $_GET['ProductID'];
mysql_select_db($database_homesteadproducts, $homesteadproducts);
$query_WADAproducts = sprintf("SELECT * FROM products WHERE ProductStatus <> 10, INNER JOIN productsubcategories ON products.ProductCatID = ProdSubCatID ORDER BY ProdSubCatID, ProductSortOrder ASC", GetSQLValueString($IDParam_WADAproducts, "int"));
$query_limit_WADAproducts = sprintf("%s LIMIT %d, %d", $query_WADAproducts, $startRow_WADAproducts, $maxRows_WADAproducts);
$WADAproducts = mysql_query($query_limit_WADAproducts, $homesteadproducts) or die(mysql_error());
$row_WADAproducts = mysql_fetch_assoc($WADAproducts);
if (isset($_GET['totalRows_WADAproducts'])) {
$totalRows_WADAproducts = $_GET['totalRows_WADAproducts'];
} else {
$all_WADAproducts = mysql_query($query_WADAproducts);
$totalRows_WADAproducts = mysql_num_rows($all_WADAproducts);
$totalPages_WADAproducts = ceil($totalRows_WADAproducts/$maxRows_WADAproducts)-1;
info271221
Attachments Pages need SQL to filter
The ProductsTest is just a simple statement that does work. I tried to follow that scenario on the other pages and it does not work.
this sql:
is not correct.
the where statement needs to be before the Order by statement:
SELECT * FROM products , INNER JOIN productsubcategories ON products.ProductCatID = ProdSubCatID WHERE ProductStatus <> 10 ORDER BY ProdSubCatID, ProductSortOrder ASC
or:
SELECT * FROM products , INNER JOIN productsubcategories ON products.ProductCatID = ProdSubCatID WHERE ProductStatus = 10 ORDER BY ProdSubCatID, ProductSortOrder ASC
