ImageFile Resize Error
Thread began 5/26/2011 5:17 am by cherry8723424721 | Last modified 5/27/2011 6:49 am by Jason Byrnes | 2523 views | 12 replies |
cherry8723424721
Hi Jason:
I'm uploading and displaying image files perfectly well in DW5 using Data Assist. However, now that I'm trying to resize the images to fit a box (200 x 200 px) I get the following error message:
Parse error: syntax error, unexpected T_ENCAPSED_AND_WHITESPACE, expecting T_STRING or T_VARIABLE or T_NUM_STRING in C:\xampp\htdocs\LovingPanda.com\EnterProfile(2).php on line 38
Why is that? When I upload image files without resizing them DW works well, but when trying to resize them, it gives an error message. Any suggestions on how to solve this?
Thank you for your attention.
please send a copy of the EnterProfile(2).php page in a zip archive so I can examine the code.
cherry8723424721
Jason:
Attached please find the page in question.
EnterProfile(2).zip
the problem is caused by the rename new file value you entered.
For the rename to, click the lightning bolt and reselect the email2 form element.
cherry8723424721
Jason:
Sorry, this is the right page.
EnterProfile(2).zip
cherry8723424721
Jason:
I reselected the email2 value, but it still gives me the error message. In looking at the code I see many "\" backslashes between line 38 and 39. Is that supposed to be OK?
still the same problem, see my previous reply:
showpost.php?p=99870&postcount=4
cherry8723424721
Jason:
I have reentered the filename email2 by clicking on the lightening bolt and selecting it, but I still get the same error message:
Parse error: syntax error, unexpected T_ENCAPSED_AND_WHITESPACE, expecting T_STRING or T_VARIABLE or T_NUM_STRING in C:\xampp\htdocs\LovingPanda.com\EnterProfile.php on line 37
The code around line 37 is this one;
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if(isset($_POST["Submit"])){
WA_DFP_UploadFiles("WA_UploadResult1", "UploadPhoto", "2", "".((isset($_POST["email2"]))?$_POST["email2"]:"") ."?$_POST[\\\"email2\\\"]:\\\"\\\") .\\\"", "true", $WA_UploadResult1_Params);
Line 37 is the indented one (WA_DFP_UploadFiles...)
this line:
should be:
WA_DFP_UploadFiles("WA_UploadResult1", "UploadPhoto", "2", "".((isset($_POST["email2"]))?$_POST["email2"]:"") ."?$_POST["email2"]:"") ."", "true", $WA_UploadResult1_Params);
cherry8723424721
Jason:
I re-installed the whole upload extension and now the file is uploading and resizing well. But the problem is that the page is no longer centered; it appears on the lef-hand side of the screen and it's a bit deformed.
Attached please find a copy of the page.
EnterProfile.zip
