Formula for shipping sizes
Thread began 5/13/2011 10:27 am by James L | Last modified 5/16/2011 7:19 am by Jason Byrnes | 1063 views | 3 replies |
James L
My client has a product that is available only in quantities of 1, 2, or 3. A single item ships in a box 8"x5"x5". But 2 or 3 items will ship in a box 14x8x5. In the checkout wizard for UPS shipping one must list the length, width, & height. I see that the lightning bolt lets me connect to a field, so I added three fields to "Items" -- ItemLength, ItemWidth, & ItemHeight. Is there a way to dynamically populate these fields with a size based on the Quantity?
so only the height and width will change.
Create 2 calculations in the eCart object:
height:
abs([Quantity] == 1)?[ItemHeight]=8:[ItemHeight]=14
width:
abs([Quantity] == 1)?[ItemWidth]=5:[ItemWidth]=8
hard set the length at 5.
James L
this doesn't seem logical to me. There's no accounting for the 1 item box and the 2-3 items box. Should it not be something like:
abs([Quantity] == 3)?[ItemHeight]=8:[ItemWidth]=14
abs([Quantity] == 2)?[ItemHeight]=8:[ItemWidth]=14
abs([Quantity] == 1)?[ItemHeight]=8:[ItemWidth]=5
the calculation is using a ternary expression.
a ternary expression is a shortened if statement using the following format:
expresion?true statement:False statement
in other words, this statement:
height:
means:
Quantity == 1?
yes: Set the Item Height to 8
No: Set the item height to 14
the height be set to 14 if the quantity is anything other than 1. Set the quantity to 2 or 3, the height will be set to 14
