Basic shipping
Thread began 5/11/2011 4:38 pm by kevin.preston332611 | Last modified 5/23/2011 7:40 am by Jason Byrnes | 2599 views | 9 replies |
kevin.preston332611
Basic shipping
I am trying to add a basic $7.50 flat rate shipping cost to any order but I cant see where to add it. I have tried this in WA_eCart_Definition_PHP.php file:
//eCart Rule
//eCart Rule
function WAEC_WA_Store_Cart_Shandard() {
$totalShipping = 7.50;
// if (true && ((sizeof($this->Items) > 0))) {
// $totalShipping += 7.50;//Result
return WA_eCart_FormatNumber($totalShipping, $this->ForceDecimalsC, $this->DecimalPlacesC);
but that didn't work and also checkout.php I tried:
$WA_PP_ECO_Set_params[0][$nextIndex] = "ShippingTotal";
$WA_PP_ECO_Set_params[1][$nextIndex] = "7.50";
$nextIndex = count($WA_PP_ECO_Set_params[0]);
neither one added the amount when the user goes to PayPal
the website is sugarforkids.co.nz
CHeers,
Kevin.
what version of power store?
Version 4.5 allows you to configure custom shipping options in the store Admin section.
kevin.preston332611
PowerStore2
In power store 2, you would need to use eCart to update the power store cart code to include your custom shipping.
kevin.preston332611
Back when I developed the site I subscribed to that plan that gave me access to eCart2. Then they took it away so I don't have it any more. In any case 3Cart simply edits files you can edit yourself. I just need to know where this needs to be changed as the changes above do not seem to carry through to PayPal.
I know there have been changes since PayPal introduced its new interface. Does anyone know what these are and where I can manually edit the code to make it work.
Cheers,
Kevin.
hand editing the shipping is not supported in Power Store. you need to use eCart to implement this.
kevin.preston332611
I don't understand why I need to buy another component just to implement something simple like flat rate shipping in a component that cost nearly $200.
Power Store 2 does not offer support for flat rate shipping.
To add flat rate shipping, you need to use the tool that was used to create the checkout functionality of PowerStore; eCart.
kevin.preston332611
Listen, when I built this site I bought PowerStore2 and subscribed to the extension subscription which allowed me to edit the shipping details. Since then you pulled the plug on the subscriptions. you will see from my history I have bough a good few product from you all I want is a little help hand coding a fixed cost onto the cart for shipping.
Please can you help a good customer out?
Cheers,
Kevin.
if there where a simple way to hand code this, I would certainly help out. I think if you look through my posting history, you will see a number of examples where I help out with hand coding.
There is no simple code fix to this though, it is a code change that needs to occur in a number of places.
This has nothing to do with your purchase history, it is simply too complex a code change for me to be able to offer support for it.
