response mail layout
Thread began 7/01/2009 3:18 am by sommar340908 | Last modified 7/07/2009 5:05 am by sommar340908 | 4678 views | 13 replies |
sommar340908
hi
2 questions,
1. in the response mail i get from the form i don't want to show the security code (unnecesary) how to get rid of it?
2. in my form all works fine. if i fill out right, everything is turning green, exept my list/menu where i select mr or mrs? can i let this turn green aswell when the user selected
anything?
txs a lot
marc
1) I think this is supposed to be excluded by name... anything that begins with Security_ should be removed automatically.
2)Apply spry validation to the field using DW Insert->Spry->list validation
sommar340908
txs ray,
you where right. in point 1 i changed the Security_ to Sicherheits_. so i changed again and it works great now.
in point 2: itried but it don't work.
i will check again this night
txs ray
sommar340908
ray,
i'm becoming very frustrated here :(
i tried it with DW Insert->Spry->list validation but it won't work at all.
don't you think it is possible to change the contact.php for the next Contact Form Solution Pack 1.03 in that manner that it contains one of each formular elements? (1 textfield, 1 password field, 1 textarea, 1 checkbox, 1 radio button, and 1 dropdown menu)
would be easyer to work with.
txs
I appreciate the suggestion... not sure how much easier it would be though... cutting and pasting and editing to make names unique should be more difficult than just adding the list validation with spry.
Here is what you shoudl have done.
1) highlight your list
2) go to insert->spry->list validation
What do you mean it doesnt' work? What doesn't work about it? What happens?
sommar340908
ok ray,
i try to tell what i've done.
i take the original contactus.php and added above "your name" a list. then i highlighted the list and did insert->spry->list validation. like you told me.
so now when i open the contactus.php in my browser the list is there with 3 entries. "select - mr - mrs". when i click the list it turns yellow. i want that the first entry does not count as a selection. so only mr and mrs. but when i select nothing at all it do not turn red or green at all like the textfields.
this is my great problem. and sorry for my bad english
txs
make sure your top option has a blank value like:
<option value="">select</option>
and it should work. Post the url if you continue to have problems.
sommar340908
by the way, ray
"I appreciate the suggestion... not sure how much easier it would be though"
it would be easy to copy paste the servervalidations and validations showif as they are not set by inserting the new form element. so it would be very nice too see this change coming. as you can assume i am not the greatest php guru, that is why i spend money for the solution pack. but it seems not so easy like i thought it would be. but i know you're the big specialist and you'll help me out of trouble :)
txs
sommar340908
this is what i did for the select
<select name="Anrede" id="Anrede">
<option value="" selected="selected">Auswahl</option>
<option value="Herr" <?php if (!(strcmp("Herr", (ValidatedField("contact","Anrede"))))) {echo "selected=\"selected\"";} ?>>Herr</option>
<option value="Frau" <?php if (!(strcmp("Frau", (ValidatedField("contact","Anrede"))))) {echo "selected=\"selected\"";} ?>>Frau</option>
</select>
Does the client spry validation work?
The reality is that 99% of the people using the page won't ever see the server validation unless they enter the wrong CAPTCHA or security answer or they have javasript turned off the spry validation catches most of it and php isn't really needed.
The server validation and showif code is exactly the same for a list as it is for a text field. But it has to be added to the server validation on top of the page as well with a unique identifier and that identifier has to be referenced in the showif. It is best to use the Validation Toolkit for this if you are not a php guru.
I'd start with getting spry to work... Then get the validation added to the server validation on top of the page... then try to get the message to show.
Take it one step at a time and it should be pretty easy to do... I'm not sold that having a sample field would help since validation still isn't quite as simple as cutting and pasting even in that case.
