UE Progress Form
Thread began 2/16/2011 6:17 pm by iansheldon422428 | Last modified 2/17/2011 12:43 pm by iansheldon422428 | 1669 views | 7 replies |
iansheldon422428
UE Progress Form
Hi WA,
I'm trying to implement the UE Progress form onto a page. Having problems I decided to try it on a completely fresh page with just a single form on it, nothing else.
<head>
<script src="webassist/progress_bar/jquery-blockui-formprocessing.js" type="text/javascript"></script>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
</head>
<body>
<div id="form1_ProgressWrapper">
<form action="" method="post" enctype="" name="form1" id="form1">
<label>
<input type="text" name="body" id="body" />
</label>
<label>
<input type="submit" name="Submit" id="Submit" value="Submit" />
</label>
</form>
</div>
<div id="form1_ProgressMessageWrapper" class="blockUIOverlay" style="display:none;">
WADFP_SetProgressToForm('form1', 'form1_ProgressMessageWrapper', WADFP_Theme_Options['WAUE:DeepJungle'], 'temp_Universal_Email_1_Progress');
</script>
<div id="form1_ProgressMessage" >
<?php require_once("webassist/progress_bar/temp_Universal_Email_1_Progress.php"); ?>
</div>
</div>
</body>
</html>
mysql_free_result($rsaccounts);
Whilst the UE code executes and the emails get sent (currently 14 in the mailing list), there is no progress form in sight.
Has the form been applied correctly to the page?
Thanks in advance to anyone that might be able to help.
Cheers
Ian
iansheldon422428
Anyone?
Hi WA,
Does anyone have an answer to this problem?
I'm sure its quick and simple!
I just need this to finish off a job.
Ian
have you double checked that the entire webassist folder has been uploaded to the server?
in fire fox, go to Tools -> Error Console, is anything reported in the errors section?
the code you posted looks correct, I would need to see the page in a browser to be able to troubleshoot what may be wrong.
iansheldon422428
Hi Jason,
Thanks for getting back to me.
Firefox Error Console is returning
Error: update_temp_Universal_Email_1_Progress is not defined
Source File: jquery-blockui-formprocessing.js
Line: 248
I'm going to create a page on my other machine, on a test site, to see if it does the same.
If the above means something to you - then great!
I'm re-uploading the webassist folder now just in case it hasn't copied everything up.
Thanks again
Ian
is this file uploaded to the server?
iansheldon422428
Yes, that file is definitely on the server.
Ian
iansheldon422428
Big thanks to Jason for helping me resolve this.
If anyone else has the same problem, I was missing a .JS and .CSS file (the extension didnt put them in for some reason)
So by adding the following directly under <script src="../../../webassist/progress_bar/jquery-blockui-formprocessing.js" type="text/javascript"></script>
<script src="../../../webassist/progress_bar/compose_Universal_Email_1_Progress_2.js" type="text/javascript"></script>
<link href="../../../webassist/progress_bar/compose_Universal_Email_1_Progress_2.css" rel="stylesheet" type="text/css" />
To the head of the page everything now works perfectly.
Cheers
Ian
