problems with firefox
index.html there is a problem with the "youth conditioning"link on the css menu . In internet explorer this link works but in Firefox it does not work
in the CSSMenuWriter/cssmw/menu.css file change:
[code]ul#cssmw ul.level-1 {
height: 30px;
left: 0;
padding-top: 40px;
}[code]
height: 30px;
left: 0;
margin-top: 40px;
Hi I have loaded the coding as you suggested and now the top link will work but I can not click any of the links underneath Youth Conditioning. I stayed up until 3 am last night and have worked on it all today. Grrrr...not sure what else I should try. Any help you can provide is so very much appreciated. :-)
I also found out that if I hold the mouse down and go down the list, release the mouse and then click on the menu ie What is youth conditioning, then I can get the menu to work below Youth conditioning
hmmm, try using:
top: 100%;
in place of:
margin-top: 40px;
omg, thank you so much! I can't believe the incredible amount of time I spent on this and you came up with a solution in 2 minutes. Thanks very much, you are very talented!
glad to hear it is working.
