Having several content page templates in a custom made Site Sculpture template
Thread began 2/02/2011 12:26 pm by regin.toftegaard421288 | Last modified 2/02/2011 12:58 pm by Jason Byrnes | 1659 views | 3 replies |
I am trying to figure out how to use Site Sculpture together with CSS Menu Writer in my work.
My intention is to create a complete site where I use a different design for many of the pages created.
However when I create a custom sculpture template I only get to choose a home page and a content page. This is not sufficient for my need. I need at least 5 different templates for this web site. How can a accomplish this with supersuite?
You will not be able to accomplish using site sculptor to create the site pages, you will need to create the site pages manually in this case.
probably the best way to accomplish this is going to be to use CSS Menu writer as a plugin page using the PHP Framework.
This way you have one menu that that you add as a plugin to the different templates.
Create each template layout using CSS Sculptor.
Create a blank page and use menu writer to create the site menu.
add the menu page using the framework builder plugin to each sculptor template layout, then save each layout as a template.
How about CSS
I can see now that I have done poorly communicating what I really need, sorry.
I have actually done exactly what you recommended. I have one menu inserted using php and then I have designed 5 different pages saved as php documents and .dwt template files.
So far everything is great.
My next step is do add a cms system to the complete site. It was here I wanted to use the site sculpture. But I can't take all those 5 sites plus the home page and make them into a site sculpture site that I can use to add a cms system to the whole site.
Is there any other way to do this?
Use powerCMS to add the CMS functionality:
powercms/
