Submit Button Does not Display
Thread began 2/01/2011 10:29 pm by bill420487 | Last modified 4/06/2011 7:05 am by Jason Byrnes | 2663 views | 7 replies |
bill420487
I have created a form in Form Builder. The submit button shows up in Form Builder and on the Dreamweaver page. It will not show up in Live View, on my test server or the production server. The entire form displays minus the the Submit button.
Here is the code for the button:
<input class="formButton" name="Consult_submit" type="submit" id="Consult_submit" value="Submit Consultation Form" onclick="clearAllServerErrors('Consult_Brassy_CSIForm')" tabindex="18" />
I have tried everything. Each time I go into your software to try to fix it, when I save the form again, I get another Submit button. In fact, if I didn't delete them, I'd have about 30 submit buttons by now.
This is the second issue I've had with Form Builder, and I'm pretty confident the issue is your program, as it was with the last issue, which really makes me resent having to get support this way for a broken product.
please post a link to your page where I can see the issue to trouble shoot
the cause.
bill420487
the cause.
consult.php
neilo
Hi William,
The button needs to be between the <form> </form> tags.
Find the block of code:
<p><span class="formItem"><span class="buttonFieldGroup">
</span></span></p>
and cut and paste it just before the closing </form> tag. Then remove the '<span class="formItem"> and </span>' (coloured blue) from that pasted block of code.
The button should now appear in your form.
You may also want to remove the left margin from the form.Brassy_CSIForm input.formButton rule at line 191 of your webassist/forms/fd_brassy_csiform.css stylesheet:
form.Brassy_CSIForm input.formButton {
margin: 0; /* changed from 0 0 0 50px */
padding: 0;
deadvoices
Having the exact same problem
contact.php
Any ideas?
In source view, you page ends abruptly just after the captcha, I suspect a php error is occurring, add the following code at line 1 of the page to turn error reporting on:
error_reporting
(E_ALL);
deadvoices
That didnt work, error messag says
"Warning: session_start(): Cannot send session cookie - headers already sent by (output started at /customers/atone.no/atone.no/httpd.www/contact.php:5) in /customers/atone.no/atone.no/httpd.www/webassist/form_validations/wavt_validatedform_php.php on line 3 Warning: session_start(): Cannot send session cache limiter - headers already sent (output started at /customers/atone.no/atone.no/httpd.www/contact.php:5) in /customers/atone.no/atone.no/httpd.www/webassist/form_validations/wavt_validatedform_php.php on line 3 "
At the top of the page.
see the following post for details on the headers already sent error:
showthread.php?t=19285
