Only want main level navigation
I have tried deleting all sublevel navigations. Level two and level three deleted fine, however i am unable to delete level one as the 'delete' button is greyed out when level one is selected?
Any help please guys?
The only entry in the tree that will have the delete button disabled is tho top level "Menu". Anything directly under menu will be the top level of your menu.
can you send a screen shot of the issue you are having?
I have this problem also, I only want a main menu with no submenus. All sublevels can be deleted except the last one below the main menu. As soon as you get to the last submenu the delete button greys out and cant be used.
Any solution to this?
I'm not sure i follow, please send a screen shot showing the problem so I can get a better understanding.
Jason
I have included a screen shot which shows the last level 1 submenu highlighted and also the greyed out delete button. As explained earlier all submenus can be deleted until only one remains and then the delete button cant be used.
If I may, can I ask if its possible to change the colour of the menu buttons and the menu background of a preset menu to a specific # colour and also how to ensure the menu occupies the full width of the fixed width page?
You need to edit the menu content s to remove the sub level navigation, you cannot remove the sub level navigation from the css design.
you can change the background color on the design tab.
