Uploading failing
Thread began 1/27/2011 9:56 am by biz295654 | Last modified 1/27/2011 3:51 pm by Dani Chankhour | 3398 views | 12 replies |
biz295654WebAssist
Uploading failing
This is domain specific, so may be a server issue. However, following your troubleshooting on another thread, I added the show error code and got this result
Status object: WA_UploadResult1
statusCode : -1
errorMessage :
clientFileName :
fileExtension :
serverFileName :
serverSimpleFileName :
serverDirectory :
contentType :
fileWasOverwritten :
fileWasSkipped :
fileWasRenamed :
fileSize : -1
isImage :
imageWidth : -1
imageHeight : -1
WA_UploadResult1_1:
clientFileName :
fileExtension :
serverFileName :
serverDirectory :
contentType :
fileSize : -1
imageWidth : -1
imageHeight : -1
Is there anything in this report that points to the problem?
My server tech had a guess about a "temp folder" issue but he has not had time to investigate that issue yet. Thanks much.
Dani Chankhour
Did you check the permissions on the Upload folder?
The folder need to have read/write permissions.
biz295654WebAssist
yes... 755, 777 is not optimal on my server
thanks
Dani Chankhour
Can you send a copy of your page so i can try to determine what the issue is.
biz295654WebAssist
OK... thanks much.
Not uploading... trying again
biz295654WebAssist
trying again with zipped
toppageadmin.zip
Dani Chankhour
Looking the uploader.php file i noticed you have spaces in the file field name ( send photo > send_photo) which could cause issues.
Try removing the space and update the Digital File Pro server behavior after you make your change.
biz295654WebAssist
thanks... I'll see what I can do...much thanks
biz295654WebAssist
made the changes yet not working...
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
<link href="admintop.css" rel="stylesheet" type="text/css" />
</head>
<body>
<form action="" method="post" enctype="multipart/form-data" name="form1" id="form1">
<p>For box 2, 3, 4 -- will resize photo to 200 pixel wide.</p>
<p>
<label for="fileField"></label>
<input type="file" name="fileField" id="fileField" />
<input type="submit" name="sendphoto" id="sendphoto" value="Submit" />
</p>
<p>You will remain on this page after upload.</p>
<p>For Box 1,<a href="uploader2.php"> use this page.</a></p>
</form>
</body>
</html>
biz295654WebAssist
but perhaps I didn't understand this part
