by the way I've also tried to uninstall extension (10 mins!!!!!!) and then reinstall, and then rebuilt pages, with same errors and problems... I've also encountered many problems with form builder, and as I can read there are many customers disappointed with many problems reports....
so please give me a real solution for all the problems I'm encountering, otherwise I will recall the money back guarantee.
here is the code of the insert page.
<?php require_once('Connections/connect_am.php'); ?>
<?php require_once("WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
// WA Application Builder Insert
if (isset($_POST["Insert_x"])) // Trigger
$WA_connection = $connect_am;
$WA_table = "portfolio";
$WA_sessionName = "WADA_Insert_portfolio";
$WA_redirectURL = "portfolio_Detail.php";
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString = false;
$WA_indexField = "ID";
$WA_fieldNamesStr = "tipologia|committente|oggetto|descrizione|foto|note";
$WA_fieldValuesStr = "".((isset($_POST["tipologia"]))?$_POST["tipologia"]:"") ."" . "|" . "".((isset($_POST["committente"]))?$_POST["committente"]:"") ."" . "|" . "".((isset($_POST["oggetto"]))?$_POST["oggetto"]:"") ."" . "|" . "".((isset($_POST["descrizione"]))?$_POST["descrizione"]:"") ."" . "|" . "".((isset($_POST["foto"]))?$_POST["foto"]:"") ."" . "|" . "".((isset($_POST["note"]))?$_POST["note"]:"") ."";
$WA_columnTypesStr = "undefined|undefined|undefined|undefined|undefined|undefined";
$WA_connectionDB = $database_connect_am;
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id();
if ($WA_redirectURL != "") {
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml"><!-- InstanceBegin template="/Templates/am_tmplt_cms.dwt.php" codeOutsideHTMLIsLocked="false" -->
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />
<!-- InstanceBeginEditable name="doctitle" -->
<title>Insert portfolio</title>
<!-- InstanceEndEditable -->
<style type="text/css" media="all">
@import url("CSSSculptor/AM2ColumnFixedLeftSidebarHeaderandFooter_AMORANGEWHITECMS_css/screen.css");
</style>
<style type="text/css" media="print">
@import url("CSSSculptor/AM2ColumnFixedLeftSidebarHeaderandFooter_AMORANGEWHITECMS_css/print.css");
</style>
<!--[if IE 5]>
<style type="text/css">
/* IE 5 does not use the standard box model, so the column widths are overidden to render the page correctly. */
#outerWrapper #contentWrapper #leftColumn1 {
width: 220px;
</style>
<![endif]-->
<!--[if IE]>
/* The proprietary zoom property gives IE the hasLayout property which addresses several bugs. */
#outerWrapper #contentWrapper, #outerWrapper #contentWrapper #content {
zoom: 1;
</style>
<![endif]-->
<!--[if lt IE 7]>
img, div {
behavior: url("../CSSSculptor/AM2ColumnFixedLeftSidebarHeaderandFooter_AMORANGEWHITECMS_images/iepngfix.htc");
</style>
<![endif]-->
<!-- InstanceBeginEditable name="head" -->
<link href="WA_DataAssist/styles/Refined_Pacifica.css" rel="stylesheet" type="text/css" />
<link href="WA_DataAssist/styles/Geneva.css" rel="stylesheet" type="text/css" />
</head>
<body>
<div id="outerWrapper">
<div id="header"></div>
<div id="contentWrapper">
<div id="leftColumn1">
<h2>GESTIONE</h2>
<h2>CONTENUTI DEL SITO </h2>
<p>MENU<a href="#"></a></p>
<hr />
<p>Lorem ipsum dolor sit amet, consectetuer adipiscing elit. Praesent aliquam, justo convallis luctus rutrum, erat nulla fermentum diam, at nonummy quam ante ac quam. Maecenas urna purus, fermentum id, molestie in, commodo porttitor, felis. Nam blandit quam ut lacus. Quisque ornare risus quis ligula. Phasellus tristique purus a augue condimentum adipiscing. Aenean sagittis. Etiam leo pede, rhoncus venenatis, tristique in, vulputate at, odio. <a href="#">More...</a></p></div>
<div id="content">
<h1>trattamento dati</h1>
<hr />
<!-- InstanceBeginEditable name="contenuto" -->
<p> </p>
<div class="WADAInsertContainer">
<form action="portfolio_Insert.php" method="post" name="WADAInsertForm" id="WADAInsertForm">
<div class="WADAHeader">Insert Record</div>
<div class="WADAHorizLine"><img src="WA_DataAssist/images/_tx_.gif" alt="" height="1" width="1" border="0" /></div>
<table class="WADADataTable" cellpadding="0" cellspacing="0" border="0">
<tr>
<th class="WADADataTableHeader">tipologia:</th>
<td class="WADADataTableCell"><input type="radio" name="tipologia" id="tipologia" value="" />
[ Label ]<br />
[ Label ]</td>
</tr>
<tr>
<th class="WADADataTableHeader">committente:</th>
<td class="WADADataTableCell"><input type="text" name="committente" id="committente" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">oggetto:</th>
<td class="WADADataTableCell"><input type="text" name="oggetto" id="oggetto" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">descrizione:</th>
<td class="WADADataTableCell"><textarea name="descrizione" id="descrizione" cols="32"></textarea></td>
</tr>
<tr>
<th class="WADADataTableHeader">foto:</th>
<td class="WADADataTableCell"><input type="text" name="foto" id="foto" value="" size="32" /></td>
</tr>
<tr>
<th class="WADADataTableHeader">note:</th>
<td class="WADADataTableCell"><input type="text" name="note" id="note" value="" size="32" /></td>
</tr>
</table>
<div class="WADAButtonRow">
<table class="WADADataNavButtons" border="0" cellpadding="0" cellspacing="0">
<tr>
<td class="WADADataNavButtonCell" nowrap="nowrap"><input type="image" name="Insert" id="Insert" value="Insert" alt="Insert" src="WA_DataAssist/images/Pacifica/Refined_insert.gif" /></td>
<td class="WADADataNavButtonCell" nowrap="nowrap"><a href="portfolio_Results.php" title="Cancel"><img border="0" name="Cancel" id="Cancel" alt="Cancel" src="WA_DataAssist/images/Pacifica/Refined_cancel.gif" /></a></td>
</tr>
</table>
<input name="WADAInsertRecordID" type="hidden" id="WADAInsertRecordID" value="" />
</div>
</form>
</div>
<!-- InstanceEndEditable --></div>
</div>
<div id="footer">
log out </div>
</div>
</body>
<!-- InstanceEnd --></html>
