Multiple Add to Cart
Thread began 6/24/2009 3:30 am by danjen | Last modified 6/29/2009 12:15 pm by Ray Borduin | 3023 views | 14 replies |
danjenBeta Tester
I am trying to create multiple add to cart interface where multiple items are added to a cart that have a checkbox.
I have added the add to cart from recordset server behavior and I have created a filter using search wizard to create recordset of the checked items. The problem I am having is that the filter is not working and it is adding everything in the database to the cart.
Here is the filter:
//WA Database Search (Copyright 2005, WebAssist.com)
//Recordset: AddToCartItems;
//Searchpage: ;
//Form: ;
$WADbSearch1_DefaultWhere = "";
if (isset($_POST["WA_Store_Cart_1_ATC_x"])) {
$WADbSearch1 = new FilterDef;
$WADbSearch1->initializeQueryBuilder("MYSQL","1");
//keyword array declarations
//comparison list additions
$WADbSearch1->addComparisonFromList("pn","addtocart[]","AND","=",0);
//save the query in a session variable
if (1 == 1) {
$_SESSION["WADbSearch1_ProductsDetail"]=$WADbSearch1->whereClause;
else {
//get the filter definition from a session variable
if (1 == 1) {
if (isset($_SESSION["WADbSearch1_ProductsDetail"]) && $_SESSION["WADbSearch1_ProductsDetail"] != "") {
$WADbSearch1->whereClause = $_SESSION["WADbSearch1_ProductsDetail"];
else {
$WADbSearch1->whereClause = $WADbSearch1_DefaultWhere;
else {
$WADbSearch1->whereClause = str_replace("\\''", "''", $WADbSearch1->whereClause);
$WADbSearch1whereClause = '';
Here is add to cart
// WA eCart Get Info From RS
if (isset($_POST["WA_Store_Cart_1_ATC_x"]) && isset($totalRows_AddToCartItems) && $totalRows_AddToCartItems > 0) {
$Redirect_redirStr="cart.php";
do {
$WA_Store_Cart_itemID = "".$row_AddToCartItems['pn'] ."";
$WA_Store_Cart_itemName = "".$row_AddToCartItems['medium_description'] ."";
$WA_Store_Cart_itemDescription = "".$row_AddToCartItems['color_code'] ."";
$WA_Store_Cart_itemWeight = floatval("0");
$WA_Store_Cart_itemQuantity = floatval("1");
$WA_Store_Cart_itemPrice = floatval("".$row_AddToCartItems['Price'] ."");
$WA_Store_Cart_itemThumb = "".$row_AddToCartItems['thumbnail'] ."";
$WA_Store_Cart_itemSKU = "".$row_AddToCartItems['brand_name'] ."";
$WA_Store_Cart->AddToCart(1, "", $WA_Store_Cart_itemID, $WA_Store_Cart_itemName, $WA_Store_Cart_itemDescription, $WA_Store_Cart_itemWeight, $WA_Store_Cart_itemQuantity, $WA_Store_Cart_itemPrice, $WA_Store_Cart_itemThumb, $WA_Store_Cart_itemSKU);
} while ($row_AddToCartItems = mysql_fetch_assoc($AddToCartItems));
if ($Redirect_redirStr != "") {
$WA_Store_Cart->redirStr = $Redirect_redirStr;
mysql_data_seek($AddToCartItems, 0);
$row_AddToCartItems = mysql_fetch_assoc($AddToCartItems);
Here is recordset:
mysql_select_db($database_localhost, $localhost);
$query_AddToCartItems = "SELECT Product_Base.pn, Product_Base.brand_name, Product_Base.color_code, Product_Base.medium_description, Product_Base.thumbnail, Product_Base.Price FROM Product_Base";
setQueryBuilderSource($query_AddToCartItems,$WADbSearch1,false);
$AddToCartItems = mysql_query($query_AddToCartItems, $localhost) or die(mysql_error());
$totalRows_AddToCartItems = mysql_num_rows($AddToCartItems);
Here is checkbox:
<td valign="bottom" width="110px"><form name="related"><input type="checkbox" name="addtocart[]" id="addtocart" value="<?php echo $row_rsRelated['AccessoryItem']; ?>" align="top"/><a href="ProductsDetail.php?SKU=<?php echo $row_rsRelated['AccessoryItem']; ?>"><?php echo $row_rsRelated['AccessoryItem']; ?></a><input name="posted" type="hidden" value="1" /></form></td>
<td valign="bottom"><?php echo $row_rsRelated['short_description']; ?></td>
<td valign="bottom" width="120" align="right">$<?php echo $row_rsRelated['price']; ?></td>
<td><form name="WA_Store_Cart_2_ATC_<?php echo $row_rsRelated['AccessoryItem']; ?>" method="POST" action="<?php echo $_SERVER["PHP_SELF"]; ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".$_SERVER["QUERY_STRING"]:""; ?>">
Can you tell me what I am doing wrong here?
Don't include the brackets in this line:
should be:
$WADbSearch1->addComparisonFromList("pn","addtocart","AND","=",0);
danjenBeta Tester
Hi Ray - Thanks for the reply. I removed the brackets and tested it and it still didn't work. It is still adding the entire database. Then I removed the brackets from the checkbox and same problem. Filter still not grabbing just the checked items.
Thanks for your help.
Leave the brackets in the checkbox name... just not in the search reference.
What button are you clicking to submit the form? Have you tried adding debug statements to see if the recordset query is updated or if the search where clause code is set?
I would try writing the sql query and where clause values and make sure the trigger is correct.
danjenBeta Tester
I put an echo of the query on the page. It is not getting to the filter. The select is for the items and nothing is being filtered
danjenBeta Tester
I am missing a step somewhere to get the checked items only into the recordset. I either have the filter in the wrong place or something.
It may be a problem with the trigger if you have changed the button name.
The code that should build the filter is:
maybe add:
die("filter: ".$WADbSearch1->whereClause);
after that line and see A if it is called and B what the where clause it thinks it should use is.
danjenBeta Tester
ok if I add that to the code, the page doesn't load. Just dies with filter:
I have not changed the name of the button and the main product is added to the cart. Now just the accessory items are not added with it.
Is there any kind of training recipe for add multiple items to cart. I am so close on this, but am getting frustrated that I am getting no where.
Here is my filter at the beginning of the page.
//Searchpage: ;
//Form: ;
$WADbSearch1->addComparisonFromList("pn","addtocartmodel","AND","=",0);
if (1 == 1) {
else {
if (1 == 1) {
else {
else {
Here is recordset:
$MMColParam_AddToCartItems = "-1";
if (isset($_POST['addtocartmodel[]'])) {
$MMColParam_AddToCartItems = (get_magic_quotes_gpc()) ? $_POST['addtocartmodel[]'] : addslashes($_POST['addtocartmodel[]']);
$query_AddToCartItems = sprintf("SELECT CartItems.pn, CartItems.brand_name, CartItems.color_code, CartItems.medium_description, CartItems.thumbnail, CartItems.Price FROM CartItems WHERE %s = CartItems.pn", GetSQLValueString($MMColParam_AddToCartItems, "text"));
Are the checkboxes in the form?
Did you have any checked?
What does the checkbox code look like when you view the source? Do you have a sample url?
danjenBeta Tester
Yes - checkboxes are in a form and they are checked.
Here is URL: ProductsDetail.php?SKU=EIFLW55HMB
I am only wokring on Recommended models right now. Then I will do warranties and accessory items
Here is form code:
<?php if ($totalRows_RelatedModel > 0) { // Show if recordset not empty ?>
<h2 style="background-color: #D3E1FB;width:680px;height:20px;padding-top:10px;"> Recommended models:</h2>
<form name="relatedmodel" method="post">
<?php do { ?>
<hr/>
<table>
<tr>
<td><table width="100%" border="0">
<tr>
<td align="left" valign="bottom"><img src="<?php echo $row_RelatedModel['thumbnail']; ?>" height="50" width="50" /></td>
<td width="100" valign="bottom" >
<input type="checkbox" name="addtocartmodel[]" id="addtocartmodel" value="<?php echo $row_RelatedModel['ModelItem']; ?>" align="top"/>
<a href="ProductsDetail.php?SKU=<?php echo $row_RelatedModel['ModelItem']; ?>"><?php echo $row_RelatedModel['ModelItem']; ?></a>
</td>
<td valign="bottom" width="200"><?php echo $row_RelatedModel['brand_name']; ?><br />
<?php echo $row_RelatedModel['medium_description']; ?></td>
<td valign="bottom" align="right" width="100">$<?php echo $row_RelatedModel['price']; ?></td>
<td valign="bottom" align="right" width="200"><form name="WA_Store_Cart_3_ATC_<?php echo $row_RelatedModel['ModelItem']; ?>" method="POST" action="<?php echo $_SERVER["PHP_SELF"]; ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".$_SERVER["QUERY_STRING"]:""; ?>">
<input type="hidden" name="WA_Store_Cart_3_ID_Add" value="<?php echo $row_RelatedModel['ModelItem']; ?>" >
<input type="text" name="WA_Store_Cart_3_Quantity_Add" value="1" size="1" >
<input type="submit" value="Add to Cart" name="WA_Store_Cart_3_ATC" align="absmiddle">
</form></td>
</tr>
</table></td>
</tr>
</table>
<?php } while ($row_RelatedModel = mysql_fetch_assoc($RelatedModel)); ?> </form>
<?php } // Show if recordset not empty ?>
