unable to turn off "test mode" in Authorize.net
Thread began 1/08/2011 4:03 pm by James L | Last modified 1/14/2011 11:45 am by Jason Byrnes | 8311 views | 15 replies |
James L
Did the thing suggested in another post, changed:
$AuthNet_required[0][$nextIndex] = "x_test_request";
$AuthNet_required[1][$nextIndex] = "TRUE";
$AuthNet_required[1][$nextIndex] = "FALSE";
But the authorize.net credit card entry page still says "test mode"...
Also on this page there is no Invoice # showing, and no Customer ID.
I was so excited to get everything working after getting your advice about uninstalling UniversalEmail 5 and reinstalling UE 4 in my extensions, if these last problems could be fixed we'd be ready to go live...
In addition to turning off test mode in the code, you need to turn it off in your authorize.net account.
James L
Your response would be more useful to me if you had explained how this would be done. The authorize.net AIM manual says this is done in the php code with " <INPUT TYPE="HIDDEN" NAME="x_test_request" VALUE="FALSE"> " which is different from the code I used (from a previous support answer). Is this what you are referring to?
No, In addition to changing the test mode setting in the code, you need to change the test mode setting in your authorize.net account, you need to log into your authorize.net account and set the account to not use test mode.
The code you posted initially is for the Advanced Implementation Method (AIM) API with Authorize.net.
The code you posted a moment ago is for the Server Implementation Method (SIM)
Which are you using?
James L
I'm using AIM, and that line of code was copied directly from their "AIM_guide.pdf"...
Also,my client has been using this account for several years, there should be no need to change the account setting...
can you send a copy of your page so I can examine the entire code to see what is wrong.
James L
which page? checkout.php or confirm.php?
confirm please, that is the page that sends the data to authorize.net.
James L
my confirm.php file
my confirm.php file
confirm.php.zip
this page is using the remote checkout method.
change:
<input type="hidden" name="x_test_request" id="x_test_request" value="TRUE" />
<input type="hidden" name="x_test_request" id="x_test_request" value="FALSE" />
the code from your initial post is used for local checkout and is not on this confirm page.
