"Insert" button trys to open Detail page with wrong address
Thread began 12/30/2010 1:33 pm by James L | Last modified 12/30/2010 3:09 pm by James L | 2208 views | 7 replies |
James L
Built my Admin back end with DataAssist and DFP. I previously posted about my major problems with the file Upload not working (resulting in an open ticket), but this current problem seems like it should be an easy fix compared to the Upload issue.
The Insert page works great, it does upload data to my database, but when it tries to open the Detail page (to display what was just uploaded) the URL is wacky, resulting in a File Not Found error.
It tries to open this URL: "http://billchisholm.com/var/www/html/chisholm/jim/admin/items_Detail.php"
But it should be opening: "http://billchisholm.com/chisholm/jim/admin/items_Detail.php"
How can I modify the code to keep it from inserting "var/www/html/"??
send a copy of the insert page please so i can examine the code.
James L
items_insert page
attached is the file
items_Insert.php.zip
try changing line 74:
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname($_SERVER["PHP_SELF"])):"";
James L
That did the trick on the Insert page. Thanks for the quick response. I assume I can do the same thing on the Details page to fix that one also?
yes, the same change should do the trick on the delete page.
James L
That works also! I wish my other WA problems were this easy to solve!
James L
I just noticed that the same thing happens when I click the "delete" button on the Detail page (the data does get deleted, but that same "www/var" stuff was added to the url of the page it tried to open
