Redirect if username exists - don't work
Thread began 12/11/2010 1:03 pm by henrik.schlegel400884 | Last modified 12/12/2010 1:16 pm by henrik.schlegel400884 | 1433 views | 4 replies |
Henrik
I have set up a Login/Registration functionality with password encryption using your security assist solutionrecipes. On the registration page the - Redirect if username exists - don't work.
The email column is the unique column and in case an email is inserted that already exists -
the user should be redirected to users_duplicate.php.
I tested several times registering with the same email -
but the redirect doesn't happen - instead a new user is registered in the database -
with same email address then the user before.
Can't find the issue here ...
Any help is most appreciated!
anonymous
Hi there,
Could you post the code here? Maybe there is an error that someone here could spot if we could see the code.
Best regards,
Brian
Henrik
Hi Brian,
thanks for your reply! Here is the php-code:
<?php require_once('../../Connections/mysql_sonic_magic.php'); ?>
<?php require_once("../../WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
<?php require_once("../../WA_SecurityAssist/WA_SHA1Encryption.php"); ?>
// *** Redirect if username exists
$MM_flag="MM_insert";
if (isset($_POST[$MM_flag])) {
$MM_dupKeyRedirect="users_duplicate.php";
$loginUsername = $_POST['UserEmail'];
$LoginRS__query = "SELECT UserEmail FROM users WHERE UserEmail='" . $loginUsername . "'";
mysql_select_db($database_mysql_sonic_magic, $mysql_sonic_magic);
$LoginRS=mysql_query($LoginRS__query, $mysql_sonic_magic) or die(mysql_error());
$loginFoundUser = mysql_num_rows($LoginRS);
//if there is a row in the database, the username was found - can not add the requested username
if($loginFoundUser){
$MM_qsChar = "?";
//append the username to the redirect page
if (substr_count($MM_dupKeyRedirect,"?") >=1) $MM_qsChar = "&";
$MM_dupKeyRedirect = $MM_dupKeyRedirect . $MM_qsChar ."requsername=".$loginUsername;
header ("Location: $MM_dupKeyRedirect");
exit;
// WA Application Builder Insert
if (isset($_POST["Register"])) // Trigger
$WA_connection = $mysql_sonic_magic;
$WA_table = "users";
$WA_sessionName = "users_UserID";
$WA_redirectURL = "users_LogIn.php";
$WA_keepQueryString = false;
$WA_indexField = "UserID";
$WA_fieldNamesStr = "UserEmail|UserPassword|UserFirstName|UserLastName|UserCity|UserState|UserZip|UserPhone|UserCountry|UserAddress";
$WA_fieldValuesStr = "".((isset($_POST["UserEmail"]))?$_POST["UserEmail"]:"") ."" . "|" . "".WA_SHA1Encryption(((isset($_POST["UserPassword"]))?$_POST["UserPassword"]:"")) ."" . "|" . "".((isset($_POST["UserFirstName"]))?$_POST["UserFirstName"]:"") ."" . "|" . "".((isset($_POST["UserLastName"]))?$_POST["UserLastName"]:"") ."" . "|" . "".((isset($_POST["UserCity"]))?$_POST["UserCity"]:"") ."" . "|" . "".((isset($_POST["UserState"]))?$_POST["UserState"]:"") ."" . "|" . "".((isset($_POST["UserZip"]))?$_POST["UserZip"]:"") ."" . "|" . "".((isset($_POST["UserPhone"]))?$_POST["UserPhone"]:"") ."" . "|" . "".((isset($_POST["UserCountry"]))?$_POST["UserCountry"]:"") ."" . "|" . "".((isset($_POST["UserAddress"]))?$_POST["UserAddress"]:"") ."";
$WA_columnTypesStr = "',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''";
$WA_connectionDB = $database_mysql_sonic_magic;
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id();
if ($WA_redirectURL != "") {
And the form-code in the body:
<div id="RegistrationContainer" class="WAATK">
<form method="post" name="WAATKRegistrationForm" id="WAATKRegistrationForm">
<h1>Registration</h1>
<table class="WAATKDataTable" cellpadding="0" cellspacing="0" border="0">
<tr>
<th>First Name:</th>
<td><input type="text" class="WAATKTextField" name="UserFirstName" id="UserFirstName" value="" size="32" /></td>
</tr>
<tr>
<th>Last Name:</th>
<td><input type="text" class="WAATKTextField" name="UserLastName" id="UserLastName" value="" size="32" /></td>
</tr>
<tr>
<th>Address:</th>
<td><input type="text" class="WAATKTextField" name="UserAddress" id="UserAddress" value="" size="32" /></td>
</tr>
<tr>
<th>City:</th>
<td><input type="text" class="WAATKTextField" name="UserCity" id="UserCity" value="" size="32" /></td>
</tr>
<tr>
<th>State:</th>
<td><input type="text" class="WAATKTextField" name="UserState" id="UserState" value="" size="32" /></td>
</tr>
<tr>
<th>Zip/Postal Code:</th>
<td><input type="text" class="WAATKTextField" name="UserZip" id="UserZip" value="" size="32" /></td>
</tr>
<tr>
<th>Country:</th>
<td><input type="text" class="WAATKTextField" name="UserCountry" id="UserCountry" value="" size="32" /></td>
</tr>
<tr>
<th>Phone:</th>
<td><input type="text" class="WAATKTextField" name="UserPhone" id="UserPhone" value="" size="32" /></td>
</tr>
<tr>
<th>Email:</th>
<td><input type="text" class="WAATKTextField" name="UserEmail" id="UserEmail" value="" size="32" /></td>
</tr>
<tr>
<th>Create Password:</th>
<td><input type="password" class="WAATKTextField" name="UserPassword" id="UserPassword" value="" /></td>
</tr>
</table>
<div class="WAATKButtonRow">
<input type="Submit" name="Register" id="Register" value="Register" />
<input name="hiddenField" type="hidden" id="hiddenField" value="MM_insert" />
</div>
</form>
</div>
Thank You!
anonymous
Ok... here's your problem.
This: <input name="hiddenField" type="hidden" id="hiddenField" value="MM_insert" />
Needs to be changed to this:
<input name="MM_insert" type="hidden" id="MM_insert" value="MM_insert" />
Because the flag is looking for is an input with the name of "MM_insert". It looks like you put it in the value rather than the name... the script though is looking for an input with that name. It's not concerned what the value is - just that variable exists.
Best regards,
Brian
Henrik
Thank you, Brain!
That was ist ...
Thanks a lot for the help!
Henrik
