No results found matching your search.
HI ok i have done this site and its been up about 1year when you use the search you get this message every time/??????????????????????/
Results Info
Results Info
Daniel,
A couple of things to check. Do you have Boss API key and is your site correctly registered within the Yahoo Developer's Library. Also, is the starting point for the search correctly identified?
Best regards,
Brian
Hi
hi im sure i put the boss api key in how would i check this??? also registered within the Yahoo Developer's Library.???? sorry its been a long time form when i put that site up
you can check the API information that was entered by double clicking the Yahho search server behavior in the server behaviors panel.
you will need to submit your site to the yahoo search engines:
submit.html
