Add to Cart Button Form Validation
Thread began 12/10/2010 11:22 am by eyoung296270 | Last modified 12/13/2010 11:50 am by Jason Byrnes | 1710 views | 7 replies |
eyoung296270
I am trying to add client side form validation using entry required for 3 fields in the form where measurements are required. When checking the validation and I click the add to cart button with no entries in any field I get the error message that the three fields are required. However when I fill in just one field the add to cart button adds the item to the cart and the form validation doesn't work.
I have tried changing the page to where the form posts with no positive results. What am I doing wrong?
impossible to tell what may be wrong without seeing the page.
please post a link where i could see the problem to be able to investigate the cause.
eyoung296270
Thanks Jason,
Here is the link: factory-spa-covers-detail-shape1-step.php?ItemsID=1&ItemColor=6&shapeID=1&ItemCatID=6
if you look at the validaiton code:
onsubmit="WAValidateRQ(document.forms[1].eCart1_1_MeasureA_Add,'- Measurement A is required',document.forms[1].eCart1_1_MeasureA_Add,0,false,'text');WAValidateRQ(document.forms[1].eCart1_1_MeasureA_Add,'- Measurement B is required',document.forms[1].eCart1_1_MeasureA_Add,0,false,'text');WAValidateRQ(document.forms[1].eCart1_1_MeasureA_Add,'- Measurement C is required',document.forms[1].eCart1_1_MeasureA_Add,0,false,'text');WAValidateRQ(document.forms[1].eCart1_1_MeasureA_Add,'- Skirt Length is required',document.forms[1].eCart1_1_MeasureA_Add,0,false,'text');WAAlertErrors('The following errors were found','Correct invalid entries to continue',true,false,false);return document.MM_returnValue"
all of the validations have been applied to the eCart1_1_MeasureA_Add form element, no valdation has been applied to the other form elements.
eyoung296270
I see that. In using the client side validation wizard I am selecting each form element and applying a required and the error text but I still get the same results. I have uninstalled the validation toolkit and reinstalled it and I get the same results. I am using dreamweaver cs3 with vista.
eyoung296270
Is there a problem with the validation toolkit and dreamweaver cs3? None of my forms are being validated properly. They all use the first field for all field validations.
eyoung296270
I have uninstalled the validation toolkit and reinstalled it. I have a better looking validation behavior but still the same results. This page does have a shopping cart on the page as well. Here is the link and any help would be appreciated.
factory-spa-covers-detail-shape2-step.php?ItemsID=2&ItemColor=2&shapeID=2&ItemCatID=92
you started a new thread for this issue here:
showthread.php?t=17671
see my reply there.
