Dynamic Menu Recordset Fail
Thread began 12/04/2010 3:41 pm by CreateColl | Last modified 12/07/2010 1:39 pm by CreateColl | 2244 views | 4 replies |
CreateColl
Hello ,
I'm on XP/ DRW CS4 build 4117 and I baught super suite last month.
I try to build a dynamic menu with CSS menu writer and I experience an issue with the recordset in "menu.php" page.
Basicly I want to call the first level of the menu with something like " index_categorie='0' "
Database structure is here :attachment.php?attachmentid=5844&stc=1&d=1291542163
When I create the recorset with the button "Edit contents" of the menu writter,
the recordset is not correct : see here attachment.php?attachmentid=5847&stc=1&d=1291542191
I can correct the code manualy but the problem come back everytime I use the button "Edit contents" .
What do you advise for that ?
Best regards
G.S
CreateColl
Hy ,
please can you explaine me why it's necessary to create a support ticket ?
I am not able to reproduce the issue, to be able to look into the cause, then fix the problem, we will need to work with you over the phone. I created the support ticket so that we could investigate the issue with you.
CreateColl
Thank you Jason
