Check Unique Record - Display Result
Hello
I read the forum to understand how to check an unique key in a table whan I use an insert transaction. I succeed it with the following code ( excuse for the length but we can make link in your forum).
Now, I would like to know how we can display the result ( in the same page ) like a message
'Duplicate record'.
Do we have to use the $_SESSION['WAVT_1_862_Errors'] with "echo $_SESSION['WAVT_1_862_Errors']"
Or $WAFV_Errors ?
because I don't know exactly what
PostResult($WAFV_Redirect,$WAFV_Errors,"1_862");
returne ?
Thank for your replay
G.S
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$colname_CHECK_UNIQUE_MAIL = "-1";
if (isset($_POST['email'])) {
$colname_CHECK_UNIQUE_MAIL = (get_magic_quotes_gpc()) ? $_POST['email'] : addslashes($_POST['email']);
mysql_select_db($database_CNX, $CNX);
$query_CHECK_UNIQUE_MAIL = sprintf("SELECT * FROM sdd_membre WHERE MAIL = %s", GetSQLValueString($colname_CHECK_UNIQUE_MAIL, "text"));
$CHECK_UNIQUE_MAIL = mysql_query($query_CHECK_UNIQUE_MAIL, $CNX) or die(mysql_error());
$row_CHECK_UNIQUE_MAIL = mysql_fetch_assoc($CHECK_UNIQUE_MAIL);
$totalRows_CHECK_UNIQUE_MAIL = mysql_num_rows($CHECK_UNIQUE_MAIL);
if (isset($_POST["WA_Insert"])) {
$WAFV_Redirect = "";
$_SESSION['WAVT_1_862_Errors'] = "";
if ($WAFV_Redirect == "") {
$WAFV_Redirect = $_SERVER["PHP_SELF"];
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateNM($totalRows_CHECK_UNIQUE_MAIL . "",-1,0,0,".,",true,2);
if ($WAFV_Errors != "") {
// WA Application Builder Insert
if (isset($_POST["WA_Insert"])) // Trigger
$WA_connection = $CNX;
$WA_table = "sdd_membre";
$WA_sessionName = "id_memb";
$WA_redirectURL = "";
$WA_keepQueryString = false;
$WA_indexField = "id_memb";
$WA_fieldNamesStr = "MAIL";
$WA_fieldValuesStr = "".((isset($_POST["email"]))?$_POST["email"]:"") ."";
$WA_columnTypesStr = "',none,''";
$WA_connectionDB = $database_CNX;
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id();
if ($WA_redirectURL != "") {
<head>
<link href="../../../Styles/form_clean.css" rel="stylesheet" type="text/css" />
</head>
<body>
<form action="<?php echo((isset($_SERVER["PHP_SELF"]))?$_SERVER["PHP_SELF"]:"") ?>" method="post" class="clean" id="form1">
<ol>
<li>
<fieldset>
<ol>
<li>
<label for="email">EMAIL</label>
<input type="text" id="email" name="email" value="" />
</li>
</ol>
</fieldset>
</li>
</ol>
<p style="text-align:right;">
<input type="reset" value="CANCEL" />
<input name="WA_Insert" type="submit" id="WA_Insert" value="OK" />
</p>
</form>
</body>
</html>
mysql_free_result($CHECK_UNIQUE_MAIL);
