New version issue
Thread began 11/17/2010 1:25 pm by biz295654 | Last modified 11/20/2010 9:57 am by anonymous | 3286 views | 16 replies |
biz295654WebAssist
New version issue
I upgraded to the latest pg, and getting a weird result on display. Seems to me this was an issue about a year ago, but when I did an upgrade, it solved. So not sure why this version is presenting the same issue.
At any rate, in the display page, the images are stacked on top of one another instead of showing the usual display.
portfolio.php
Any thoughts before I reinstall?
Thanks as usual.
anonymous
I had the same issue that you are experiencing and they just opened a support ticket for me. I will report back what I find out.
What appears that is happening is the paths to the javascript and css are not getting populated correctly.
So a quick fix would be to get the links for the imports (by checking the page source)... then copy them into the head of the page that your gallery resides on and then manually edit to make sure the paths are correct. Then you're gallery will work until there is a fix.
Best regards,
Brian
biz295654WebAssist
Thanks much... I'll see if I can track it down. :-)
biz295654WebAssist
Can you give me another clue, please...
I am using php inserted:
$pg_id = '1';
$pg_theme = 'light';
include('/var/www/html/2010gallery/galleries/ribbon_fullsize_lightbox/index.php');
the path looks right... so where am I looking for bad paths...
thanks much
ah... maybe in the 'galleries' folder... downloading now...
anonymous
Yes... By viewing the source on the page from the link you provided, you will notice these import links:
<style type="text/css" media="all">
@import url("/css/slimbox/slimbox.css");
@import url("/galleries/ribbon_fullsize_lightbox/css/common.css");
@import url("/galleries/ribbon_fullsize_lightbox/css/light.css");
</style>
<script type="text/javascript" src="http://ajax.googleapis.com/ajax/libs/jquery/1.4/jquery.min.js"></script>
<script type="text/javascript" src="/js/mootools-core.js"></script>
<script type="text/javascript" src="/js/mootools-more.js"></script>
<script type="text/javascript" src="/js/slimbox.js"></script>
<script type="text/javascript" src="/galleries/ribbon_fullsize_lightbox/js/gallery.js"></script>
As you can see, the paths are not correct for the src attribute.
So, copy those into the head of your page and then append the sources to make the paths correct.
For example,
Then it would become:
<script type="text/javascript" src="/galleries/js/mootools-core.js"></script>
You need to copy the whole block, though, and edit all of them and you should be good to go until there is a permanent fix.
Best regards,
Brian
biz295654WebAssist
You're the best!
Thank you for the detail.
biz295654WebAssist
well, I tried to follow your directions, but didn't get there... used this
<script type="text/javascript" src="<?php echo $pg_config['path']; ?>/galleries/js/mootools-core.js"></script>
<script type="text/javascript" src="<?php echo $pg_config['path']; ?>/galleries/js/mootools-more.js"></script>
<?php $js_mootools = true; } ?>
<?php if(empty($js_slimbox)) { ?>
<script type="text/javascript" src="<?php echo $pg_config['path']; ?>/galleries/js/slimbox.js"></script>
<?php $js_slimbox = true; } ?>
<script type="text/javascript" src="<?php echo $pg_config['html_prefix']; ?>/galleries/js/gallery.js"></script>
<?php if(!$included) { ?>
but get this
portfolio.php
so I am missing something....
thanks for sharing...
biz295654WebAssist
more detail... when I click on a missing gif I get this path
so there is something wrong yet with paths...
anonymous
Originally Said By: biz295654
but get this
portfolio.php
Yes... you no longer need to have this: <?php echo $pg_config['path']; ?>
Since you are manually hard coding the path, you don't need to duplicate any of it.
So just create the paths in relation to the page. If your page is on the root level of your site and the Power Gallery is in folder named "galleries", then your path should just start out "src=/galleries/etc."
biz295654WebAssist
Thanks for the pointers..
Here's what I have now:
<?php } ?>
@import url("<?php echo $pg_config['path']; ?>css/slimbox/slimbox.css");
@import url("<?php echo $pg_config['html_prefix']; ?>css/common.css");
@import url("<?php echo $pg_config['html_prefix']; ?>css/<?php echo $pg_theme; ?>.css");
</style>
<?php if(empty($js_mootools)) { ?>
<script type="text/javascript" src="/galleries/js/mootools-more.js"></script>
<script type="text/javascript" src="/galleries/js/slimbox.js"></script>
<script type="text/javascript" src="/galleries/js/gallery.js"></script>
</head>
<body class="pg">
<div id="pgOuterWrapper">
<?php } ?>
But no joy. I think I'm going to strip it all out and install the previous version.
Ah... I just saw another set of config path... I'll do an update...
