Css Menu fails to process menu
Thread began 11/17/2010 8:19 am by mikelally319342 | Last modified 11/30/2010 11:51 am by roby258376 | 2552 views | 10 replies |
mikelally319342
When I click the finish button, a 'WebAssist Site Tools' pop-up box appears on the screen to signal that the process of creating the menu has commenced. However, it seems to freeze or stop at the 'initializing' stage - nothing further happens. Can you help?
have you tried deleting the Dreamweaver cache file from the users configuration folder:
what version of Dreamweaver are you using?
What is your OS?
mikelally319342
Jason - Yes, I deleted the cache and restarted Dreamweaver and it is still doing the same thing. I am using CS3 and Windows XP Professional - Mike
What is the build of Dreamweaver?
Go to Help -> About Dreamweaver.
when the about dialog opens, click it once to scroll to the end, the build number will be listed there, please post that back.
mikelally319342
Version 9 . Build 3453
Build 3453 is a pre release beta build. This build has a bug that was resent in the beta release that causes floater panels not to function correctly, the site tools is in a floater panel so it is being effected by this bug that was present during DWCS3 beta testing.
The official release build of DW CS3 was build 3481, you will build 3481 in order for menu writer the function properly.
mikelally319342
Should I use CSS Menu Writer 1 instead of version 2?
you will have the same issue with menu writer 1, it is a Dreamweaver bug that was present in the beta release that is causing the issue.
It used to be that you could download the CS3 Demo version to get the release build, but they only have the currant version available as a demo download on the adobe site. you could always use the CS5 demo version.
mikelally319342
I purchase CS5 and see how it goes. Thanks once again for your help!
you're welcome.
