Problems with Form Builder 2
Having uninstalled form builder 1 and installed form builder 2 everything seemed to work fine until I needed to use Theme it do make some adjustments, When I clicked on the icon to activate the program I got the error message shown in the attachment.
Also as I have been asked to produce a multilingual web site (English and Spanish) how can I translate the English security questions into Spanish?
I am also concerned by the length of your CSS files. Is it too much trouble to expect you to produce a CSS file for EACH variation of form, e.g. Brassy or Cool, instead of the ridiculaously complex CSS file you offer that covers ALL the variations. At a purchase price of $250 that should be something purchasers should expect by right. This applies to all your other extensions where lazyness has become the order of the day.
Can I ask your designers to endeavour to HELP your Clients rather than causing them totally unnecessary work searching through totally unnecessary reams of CSS properties.
If your designers were methodical, in their approach to design, such a request would not be necessary. This approach goes against ALL the principals of good coding. For example the "cool simple" form has several properties listed for a "datepicker" which is NOT contained on the basic form and indeed would not normally be found on a contact form.
This work should be undertaken by yourselves NOT your Clients.
Regards
Peter
