CMS Page Update Bug (when using "|" symbol)
Thread began 10/26/2010 10:52 am by washingtown364312 | Last modified 10/27/2010 11:49 am by Jason Byrnes | 1665 views | 5 replies |
washingtown364312
When using the CMS to edit content, the CMS does not retain any content after using the "|" symbol.
Steps to reproduce the bug:
Open the Admin CMS in a browser. Login as usual and edit the text content of say the Home page. Type the word "before", then type the "|" symbol, then type the word "after". You really can use anything. But any phrase after the "|" symbol will disappear on clicking the update button. Very frustrating - I lost a lot of original copy that way.
Actual Results:
The CMS will only update content that was placed before the initial "|" symbol.
Expected Results:
I want the CMS to accept the use of the "|" symbol. Also, I would like to be able to edit the source code using Dreamweaver also. How do I do that?
This is fixed in the 2.0.2 update that was recently released.
Please download the update from your download center to correct this problem.
CraigRBeta Tester
Hi Jason.
This error was logged under Site Sculptor, which is still in 1.0.0
Does this problem occur with CMS created by site sculptor ?
thanks for the catch Craig.
to fix the issue in Site Sculptor, add the following code at line 1 of the admin/contents_update.php page:
if(!empty($_POST)) {
    foreach(
$_POST as $key => $value) {
$_POST[$key] = str_replace("|""&#124;"$value);
CraigRBeta Tester
Cheers Jason.
Is there a dot release planned, or is there somewhere i can add the relevant code to the extension so new instances of the CMS will be up to date?
yes this will be fixed in a dot release, until then, you can apply the edit to the following page in the configuration folder:
Configuration/Shared/WebAssist/SiteSculptor/cms/files/admin/contents_update.php
