Form not submitting
Thread began 10/21/2010 11:18 am by dave378160 | Last modified 10/22/2010 9:21 am by Jason Byrnes | 1131 views | 9 replies |
dave378160
Form not submitting
I have this form I built here. contact.php I didn't build the site, just built the form. It's hosted on the same server my site is so I know that isn't an issue. I had them update the version of PHP to PHP5+. When the form is filled out and submitted the URL changes to this contact.php?invalid=true I can't figure out if it's Universal E-mail or CSS Form Builder.
Can someone look at it?
can you send a copy of the page in a zip archive so I can examine the code.
dave378160
Like this?
contact.php.zip
ok, to find which validation is failing, find this code:
if ($WAFV_Errors != "")  {
    PostResult($WAFV_Redirect,$WAFV_Errors,"contact");
and change it to:
die($WAFV_Errors);
I'm thinking it might be a session management issue, upload the session test file from this thread then post back:
showpost.php?p=23826&postcount=2
dave378160
When I click the first Set Session test it shows this in the URL.
sessionTest.php?test=test
When I click the second Test Session is shows this in the URL.
sessionTest.php
I also implemented the script change and now when I hit submit is goes to a white blank page, doesn't change the URL, the page just goes blank.
change this line:
$WAFV_Errors .= WAValidateRQ((isset($_POST["Contact_Form_group_Sample_FIle_Upload_MB_Max_size"])?$_POST["Contact_Form_group_Sample_FIle_Upload_MB_Max_size"]["name"]:"") . "",false,5);
$WAFV_Errors .= WAValidateRQ((isset($_FILES["Contact_Form_group_Sample_FIle_Upload_MB_Max_size"])?$_FILES["Contact_Form_group_Sample_FIle_Upload_MB_Max_size"]["name"]:"") . "",false,5);
dave378160
Okay that worked. What I wonder is why did it set itself up that way? Do I need to update something I'm using?
Also, the file upload section says it's "required" with the asterisk and I never checked that box. It just did it by itself.
If I don't attach a file it blanks out. Strange.
It's a bug in the extension it should be fixed in a future release.
if you do not want the file upload to be required, delete the line:
dave378160
Thanks again Jason, that worked. I also just deleted the Asterisk as well. Thanks for the help. I truly do appreciate it. With support like this I'll be sure to stay a loyal customer.
You're welcome.
