Form Fields with Validation further out
Thread began 10/09/2010 3:32 pm by dave378160 | Last modified 10/21/2010 8:28 am by Jason Byrnes | 1319 views | 3 replies |
dave378160
I have this form that I'm building using CSS Form Builder. The fields that require validation are shifting outwards but the fields that don't are sitting where they are supposed to. Here is the link to the page in question.
contact.php
I've been adjusting it via the style sheet rather than in the form builder because it has a tendency to crash on me a lot. Might be my computer though. What css do I need to look for to get this working correctly?
Also, why does the file upload field show that it is required when that box is not even checked in the form builder?
in the CSSFormBuilder/FD_Sharp_Default.css file, change the margin-left for the form.Sharp_Default div.errorGroup to 175px
form.Sharp_Default div.errorGroup {
margin-left:175px;
The required issue with the file field is a bug that was recently discovered, we will be fixing this in a future release.
dave378160
Thanks, that worked. I'll have to post a new thread because it's not submitting. It might be because the file upload option I added? For some reason it's got a required asterisk on it.
you can remove the required validation from the server validations server behavior.
in the server behaviors panel, double click the server validations server behavior, select the required validation for the file field and click the minus button.
