Two Date Range Searches
Thread began 10/04/2010 12:21 am by Michelle141190 | Last modified 10/05/2010 2:22 pm by Jason Byrnes | 547 views | 1 replies |
Michelle141190
I have a date range search that works fine. My problem is that I need to pull two date ranges so that I can compare them. Does anyone know of a way to do this? I am using Dreamweaver CS5 and asp. I am fine with manually changing the code if anyone knows what I could do. I need the information all in one recordset so that I can display the results under each other in a horizontal loop. When I do two separate recordsets, the second one displays repeatedly in each cell of the first recordset.
Hope this makes sense.
Thanks,
Michelle Pasquale
I'm not sure i completely understand what you are trying to accomplish.
are you trying to do the same date range search on 2 tables on one page?
If the data in the two tables is not related, you would need to create to results areas, one for each recordset.
Create a repeat region to show the data from the first recordset, then another repeat region below it to show the data from the second recordset.
