Cookies Toolkit Does not work with Secruity Assist
Hi there, I have just purchased "Dynamic Suite" and I am using Dreamweaver CS5 (on a Windows 7 platform with all the latest drivers, updates fresh install).
Once I have installed all the 4 plugins from the dynamic suite. i have found on every test i perform that Cookies Toolkit does not allow me to "Clear Session Values" on the options for that plugin.
I have done some experimenting with installing/uninstalling the other 3 plugins and have Cookies Toolkit working with all the plugins EXCEPT....Secruity Assist. Once I have uninstalled Secruity Assist then Cookies Toolkit works.
Please I need all the plugins to work together since I did purchase as a whole :)
Is there a fix for this? (i have tried the usual clear dreamweaver cache file etc etc)
I get the following error when i try to use the Cookies Toolkit (with Secruit Assist installed)
While executing onLoad in WACT_ClearSession.htm, the following Javascript error(s) occured:
At line 353 of the file C:\Users\My System\AppData\Roaming\Adobe\Dreamweaver\CS5\en_US\Configuation\Shared\WebAssist\Cookies\Library\WA_Configuation.js":
getTagProp is not defined
Please help me :)
regards
Chris
