Contact form not submitted - get ?invalid=true
Thread began 8/22/2010 7:58 pm by cldsk369146 | Last modified 8/31/2010 10:05 am by Jason Byrnes | 1236 views | 9 replies |
cldsk369146
Hello, I am trying to get a contact form working. I have successfully used form builder and universal email for several contact forms, but this one is giving me a problem.
It is currently found on contact.php
It has a couple unique features that the other forms I made didn't which might be the problem:
It has a file uploader (should be a not required field)
It has a progress bar
It has multiple e-mails that it would send to based on the Department/Concern drop down menu (a couple of the department/concerns have the value as two e-mail addresses separated by a semi-colon).
Currently, when the form is submitted it returns the following value: contact.php?invalid=true it does not go to my success page submitted.html as I put in the wizard, and it shows the form still filled out, with nothing submitted to the email addresses. I can't seem to figure this out. Your help is truly appreciated!
I uploaded the files that I hope are needed to help solve this problem.
crespi drama contact.zip
crespidrama CSSFormBuilder.zip
the invalid=true querystring variable maens that alidation has failed.
try changing:
$WAFV_Errors .= WAValidateRQ((isset($_POST["fieldset_group_File_Picture_Upload"])?$_POST["fieldset_group_File_Picture_Upload"]["name"]:"") . "",false,6);
$WAFV_Errors .= WAValidateRQ((isset($_FILES["fieldset_group_File_Picture_Upload"])?$_FILES["fieldset_group_File_Picture_Upload"]["name"]:"") . "",false,6);
cldsk369146
I did that, but still getting the same error. No required field seems to be missing, so not sure why it isn't working.
ok, in the contact page, change:
if ($WAFV_Errors != "")  {
    PostResult($WAFV_Redirect,$WAFV_Errors,"contact");
    die($WAFV_Errors);
this will write a comma separated list of validation errors to the screen to help me determine what is failing.
cldsk369146
Many thanks for the response. I did this, and the following came up after submitting a form:
,6
OK, 6 is the file field, are you selecting a file to upload?
maybe try changing the code I gave you previously:
$WAFV_Errors .= WAValidateRQ((isset($_FILES["fieldset_group_File_Picture_Upload"]["name"])?$_FILES["fieldset_group_File_Picture_Upload"]["name"]:"") . "",false,6);
cldsk369146
Many thanks for the suggestions, here is where I am at right now:
I entered the new code you gave me above, when I try to submit the form without the file upload I get the ",6" error. When I select a file to upload, it gives the progress bar, and submits. I get the email sent to me, but without the file attachment.
I do want the form to have the file upload as an option, not a requirement. It is set as that in form builder, but seems to not be correct somewhere in the code? Also, when someone ataches the file, I would like the file to be attached to the e-mail it is sent to.
Hopefully this helps, thank you for your help with this issue!
this line:
is requiring that a file be uploaded.
if you do not want to force the file upload, then delete that line.
for the attachment:
Where you are using file upload to store the file on the server, you cannot use the From Upload Option.
On the attachment tab, select the Entered Value option.
Click the lightning bolt and select he Server Directory from the Uplaoded Files (File Field) binding group.
this will add code similar to:
<?php echo $WA_DFP_UploadStatus["WA_UploadResult1"]["serverDirectory"]; ?>
copy that code, then click the lightning bolt again. This time, elect the Server File Name binding. This will create code similar to:
<?php echo $WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"]; ?>
you need to paste the server directory code in fromt of that so you get:
<?php echo $WA_DFP_UploadStatus["WA_UploadResult1"]["serverDirectory"]; ?><?php echo $WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"]; ?>
cldsk369146
Many thanks, I was finally able to get it working! I appreciate your help!
great, glad to hear it is working.
