mysql error message on confirm.php
Thread began 8/13/2010 2:37 am by lightwalkercreations361768 | Last modified 8/14/2010 4:16 am by lightwalkercreations361768 | 977 views | 2 replies |
lightwalkercreations361768Beta Tester
Dear Webassist,
I keep getting an error trying to assign the transaction id and correlation id to the DB. I have narrowed it down to one or both because when I remove them then the page processes with no trouble. the mysql error is
"You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '[OrderTransaction ID],OrderReceiptID,OrderVisitorID,OrderShipping,OrderTax,Order' at line 1"
I am not sure how to fix this. I have included the confirm.php page.
I am also having a problem were my ecart object is set to UKP but the transactions for website payment pro as come through as USD. I read a few other Post and found this
"and change it to:
<input type="hidden" name="currency_code" id="currency_code" value="GBP" />"
to change the hidden field called "currency_code" on the confirm.php. I can not find that hidden field and wondering how I can change this - I am using ecart 5 if this makes a difference.
Many thanks as always for you help
confirm.php.zip
If you are sure that the columns are properly configured then there might be an issue with the values that are going into them. The best way to help debug what is wrong with the query is to get the full query text and check it for problems, then we can make any updates that are needed in the store order summary server behavior.
To get the full text of the query you should add in this line of code just after what is currently on lines 460 and 470, add a new line after the one that starts with "$WA_Sql = " and put this code on it:
die($WA_Sql);
After you add in this code run a test and it should print out the query that is used. If you can't identify any issues with it post back with what you get and we will check it out.
For the currency code you should check lines 238-239
$PP_DirectPayment_required[0][$nextIndex] = "Currency";
$PP_DirectPayment_required[1][$nextIndex] = "USD";
You need to update the USD to GBP.
Thank you so much Eric,
I have to apologize, I made a mistake in the DB were I had a space in the row name causing the SQL error. having looked at something for so long I forget to always look at the simplest explanation.
Thank you for the help with how to change the currency. Everything is working well.
Best Wishes and again thank you for your support.
