Question about jquery-blockui-formprocessing.js
Thread began 6/06/2009 2:25 am by I-CRE8 | Last modified 6/10/2009 8:05 am by Danilo Celic | 3388 views | 3 replies |
I-CRE8Beta Tester
* Note: Modified blockUI v2.16 code to not use jQuery.boxModel within the setExpression string. (lines 227-229 in full code
I use BlockUI in the app that I use DFP and I wondered why you chose to delete the above lines as commented in the source code ?
Danilo Celic
I think what you question is really driving at is should you be making the same changes that we did. The short answer is probably not. The long answer follows...
We actually didn't delete the lines mentioned, we changed the code slightly to make the DFP use of the BlockUI plugin work in IE6.
The specific issue is that jQuery can be set to be used in a no conflict mode, and the BlockUI plugin was not written in a manner that seemlessly allowed for no conflict mode. No Conflict mode allows the jQuery library to be used with different versions on the same page. As we couldn't be absolutely certain that a page will have jQuery on the page, much less a specific version of jQuery on the page, a copy of jQuery library is linked to the page and jQuery.noConflict() is used. We assign the jQuery object returned from noConflict to a variable (named WADFP_jQuery) and we then use that variable as the jQuery object instead.
The lines in question are:
full ? s.setExpression('height','Math.max(document.body.scrollHeight, document.body.offsetHeight) - (jQuery.boxModel?0:'+opts.quirksmodeOffsetHack+') + "px"')
and:
full ? s.setExpression('width','jQuery.boxModel && document.documentElement.clientWidth || document.body.clientWidth + "px"')
And we changed them to:
full?s.setExpression("height","Math.max(document.body.scrollHeight, document.body.offsetHeight) - ("+($.boxModel?0:opts.quirksmodeOffsetHack)+')+"px"')
and:
full?s.setExpression("width",($.boxModel?'true':'false')+' && document.documentElement.clientWidth || document.body.clientWidth + "px"')
setExpression evaluates an expression at runtime, and with the jQuery.boxModel value directly within the string that is to be evaluated, that caused an error as the jQuery object didn't exist at run time as it had been "renamed" to WADFP_jQuery due to the use of noConflict. This issue only showed up for me when using IE6 in testing. The changes apply the appropriate values into the string that is to be evaluated without referencing the jQuery name. We needed to do this, because in noConflict mode, the jQuery object named "jQuery" doesn't exist in the global scope when this code is executed.
If you're using jQuery and the BlockUI plugin and you are not using noConflict to create your own version of jQuery for compatibility purposes, then you do not need to worry about integrating these changes into your own code.
FWIW: I reported this issue on the jQuery Google Group which is used for support for this plugin, but I don't know if this workaround will be integrated into a new version of BlockUI.
I-CRE8Beta Tester
Thank you Danilo for such a comprehensive answer, I am not using jQuery in no conflict mode as it is the only js library that I am using in this app so it sounds like I should be good to go.
Danilo Celic
Yes, you are good to go.
