Menu writer rearranging my top level links
I would like my menu items to appear in the same order as they are in the code, but they don't. I'm not sure where to start fixing this. Help please?
Index.aspx
Index.aspx
in the menu.css file, edit the ul#cssmw li sselector to float left instead of right
ul#cssmw li {
background-image: none;
float: left;
padding: 0 0 0 0;
position: relative;
white-space: nowrap;
z-index: 100;
If you use float right on the LI elements, it will start from the right side and build to the left.
to move the menu to the right, create a div around the menu. Set the width to be the totla widtyh of the menu and set it to float to the right.
