Digital File Pro 1.1.3
I'm a bit of a newbie but trying hard! I'm attempting to use the older version of Digital File Pro (1.1.3) to upload images into an sql 2000 database from a classic asp page. Two questions; 1) i assume the DB field type needs to be set to "Image", and 2) dreamweaver CS3 is only allowing me to insert the form field into the db as either 'text' or 'numeric'. I've tried several variations in both DB and with the server behavior, but it doesn't upload to the DB or to the designated upload folder. Can someone help this rookie out with making this work? thanks much!!!
