New Columns not added to cart or database
I have an Ecart 5 application for conference registration. It worked fine until I started adding columns to the Ecart object to capture more data. Here's the issue:
The registration involves purchasing exhibitor booths. Once a booth is purchased there are options to buy electrical hookups, another to order a corner booth and one to order a sales spot. They are items in the products table.
The items are added to the cart fine with all of the fields except for the new fields that I added to the ecart. I added a field to hold the value "Yes" when either a comer booth, electric hookup or sales spot is added to the cart. However, the values for these columns are not there when I use the cart binding for the column. I'm trying to add the value to the registration table via an insert on the confirm page and can't seem to get the values from these columns.
Am I missing something here? Maybe there is a better way to do this? I thought it would be easy to add a column, edit the add to cart button to bind the column to a default value of "Yes" and then grab that value from the cart in the bindings panel to insert into a table on the confirm page.
I really need to get this working ASAP as the registrations have started and the client is having to manually adjust each order. I'm a Library subscriber.
Thanks,
Tony
