Mega menu builder
Better menu builder, adding in mega menu feature...
Messing around with css menu writer and by putting a div and ID, changing in css, I made the start of a mega... :-)
Looking good biz. Just so you know, I was able to create a menu like the example you displayed in the earlier post. I did it using CSS Menu Writer just as the starting point and I then I just added the HTML code to each menu item. I don't operate the site any longer where I had deployed it but I can confirm that with just a little modification, you will be able to get it to look just like you want.
Best regards,
Brian
Cool, thanks for the examples. You should be able to get the result you want and it looks like you are on that track. Thanks for the suggestion of integrating it into the product itself, we'll look into it.
it would be nice to set the max width and all the buttons would fit and spread automaticly to the max width so that they have all the same padding :-)
