Title of album
the example format for Grid+Lightbox includes the title "My Vacation" in the upper left - can I add this to Ribbon+Fullsize
thanks
victor
thanks
victor
In the grid + lightbox design the title is listed using this code:
<!-- gallery title -->
<span class="title"><?php echo $gallery['title']; ?></span>
You can add this into the index.php page for the ribbon + fullsize gallery just after line 41 to get this same info on that gallery type. This same code should work for any of the galleries if you add it into the code on the index page for that gallery.
where would I then enter the actual title
thanks
victor
The title comes from the php code, it is held in the db. It will be set to whatever you have set the name of the gallery to in the admin arear. You could also replace the php code with whatever Title that you would like to add in.
