I cant...
Thread began 6/02/2009 9:58 am by meister281653 | Last modified 6/03/2009 2:39 pm by meister281653 | 3200 views | 6 replies |
meister281653
I cant...
Sorry,
but I think I am to Stupid, to use the Contact Form.
I want to create a FORM on my own.
And just have a captcha on it. I allready got the universal email extension and the veryfy tool kit extension. why do i have to upload, that stuff double.
it totally makes me nuts, why isnt there a simple tutorial how to start from the bottom.
I want to use the full extensions not only piceses.
i bought it in the beginning, and never get it right to use it.
THIS SUCKS!
Where are you getting stuck? You can use the tools... that is what we did to create the contact form.
Go ahead and create your form on your own.
Go ahead and add CAPTCHA
What steps are you missing?
Use the full extensions.... I'm afraid I don't really understand where you are getting stuck otherwise I could try to explain it better.
meister281653
it stucks right in the START.
when i create a form, I gonna use, my validation tool kit to verify. so, at least I got 2 VTK links in my page. one for the fields and the other for the captcha.
do I need that glbal thing? when i got the universal email 3 extension?
i cant find any description how to start if you got all the extensions. so the thing is, I need the contact form only for the captcha, nothing, more.
and that makes the thing that hart to understand.
Denis
You should be double clicking on the server behaviors to see how they are applied if you own the tools.
If you want to move the captcha to a new page. Just copy and paste the captcha image and add a form field where someone would fill in the answer. Then look at the server behavior for how it was validated and add similar validation for your new page.
meister281653
I opend a support ticket. I dont know how to explain.
I just want that cpatcha in my form. thats all.
Copy and paste the captcha image from ours page to yours.
Remove all of the parameters so the src just references the captcha image.
A session variable will be stored with the text from the captcha... you can use "like entry" server validation to make sure what the user enters matches the session variable.
Not sure how else I could describe it. Where are you getting stuck?
meister281653
I got it now, by try and error.
Maybe I am blind, but there is no solution, how to do it. You have to rename a lot, and direct to other folders.
But I made it finally.
Now its, nice :-)
