Add to cart pop up
Thread began 6/28/2010 1:13 pm by californiadiva80321412 | Last modified 7/02/2010 5:06 pm by Jimmy Wu | 4783 views | 4 replies |
Add to cart pop up
I have created a cart page and add to cart buttons on my product pages which is all working correctly.
When the customer clicks the add to cart button, I would like a pop up window to display a confirmation that the item has been added, do they want to continue shopping or view cart - you know the type.
So, I have created the CSS and JS pop up, which works fine on it's own, however, when I add it to the button behaviour, it flashes up but disappears. How can I make it stay open? Does anyone have any idea?
Thanks in advance.
Jimmy Wu
I'm not sure how your popup is set up and it is actually something that isn't supported since it requires custom coding, however it could have something to do with the add to cart button forwarding to another page that is causing the window to close again. Maybe if you posted a link to the page, someone will have a better idea and can help you out.
Originally Said By: Jimmy Wu
Hi Jimmy.
I had the same thought with regards to the page forwarding but even after removing forwarding links, it doesn't seem to work properly. I thought that it maybe a conflict with the mini cart so created a new blank page, but the css window only shows for a second and then closes.
I have a local server set up so can't provide a link to the page, but here is the code for my new blank page which may help...
//WA eCart Include
require_once("WA_eCart/CRCart_PHP.php");
$CRCart->GetContent();
// WA eCart AddToCart
if (isset($_POST["CRCart_1_ATC"]) || isset($_POST["CRCart_1_ATC_x"])) {
$ATC_itemID = $_POST["CRCart_1_ID_Add"];
$ATC_AddIfIn = 0;
$ATC_RedirectAfter = "";
$ATC_RedirectIfIn = "";
$ATC_itemName = "gdsa";// column binding
$ATC_itemDescription = "fda";// column binding
$ATC_itemWeight = floatval("0");// column binding
$ATC_itemQuantity = "".$_POST["CRCart_1_Quantity_Add"] ."";// column binding
$ATC_itemPrice = floatval("2.00");// column binding
$ATC_itemThumb = "";// column binding
$ATC_itemQuantity = floatval($ATC_itemQuantity);
if (is_numeric($ATC_itemQuantity) && $ATC_itemQuantity != 0) {
$CRCart->AddToCart($ATC_AddIfIn, $ATC_RedirectIfIn, $ATC_itemID, $ATC_itemName, $ATC_itemDescription, $ATC_itemWeight, $ATC_itemQuantity, $ATC_itemPrice, $ATC_itemThumb);
if ($ATC_RedirectAfter != "" && $CRCart->redirStr == "") {
$CRCart->redirStr = $ATC_RedirectAfter;
if (isset($_SERVER['QUERY_STRING']) && $_SERVER['QUERY_STRING'] != "") {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF']."?".$_SERVER['QUERY_STRING'];
else {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF'];
// WA eCart Redirect
if ($CRCart->redirStr != "") {
header("Location: ".$CRCart->redirStr);
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
<title>CSS PopUp Demo</title>
<script type="text/javascript" src="csspopup.js"></script>
<style type="text/css">
#blanket {
background-color:#111;
opacity: 0.65;
position:absolute;
z-index: 9001; /*ooveeerrrr nine thoussaaaannnd*/
top:0px;
left:0px;
width:100%;
#popUpDiv {
position:absolute;
background-color:#eeeeee;
width:300px;
height:300px;
z-index: 9002; /*ooveeerrrr nine thoussaaaannnd*/
</style>
<!--[if gte IE 5]> <style type="text/css"> #blanket {filter:alpha(opacity=65);}</style><![endif]-->
</head>
<body>
<div id="blanket" style="display:none;"></div>
<div id="popUpDiv" style="display:none;">
<a href="#" onclick="popup('popUpDiv')">Click Me To Close</a>
</div>
<form name="CRCart_1_ATC_0" method="POST" action="<?php echo $_SERVER["PHP_SELF"]; ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".$_SERVER["QUERY_STRING"]:""; ?>">
<input type="hidden" name="CRCart_1_ID_Add" value="0" >
<input type="text" name="CRCart_1_Quantity_Add" value="1" size="4" >
<input type="submit" value="Add to Cart" onclick="popup('popUpDiv')" name="CRCart_1_ATC">
</form>
</p>
</body>
</html>
Ok, managed to do a bit of a bodge job with it. For anyone who wants to know how I did it, here it is...
I changed the button on the page to just a static button that opens the css window. At this stage, the product isn't actually added to the cart. The window opens and this is where I put in the add to cart button but displayed as the continue shopping or view cart button. When either button is clicked to close the window, the product is added to the cart.
I hope that makes sense.
Jimmy Wu
Great to hear you were able to get this working. If you run into any additional issues, feel free to open a new thread.
