Help! PHP errors using require_one
Thread began 6/26/2010 11:06 am by trish408999 | Last modified 6/28/2010 4:03 pm by Jimmy Wu | 1405 views | 3 replies |
trish408999
Created my site in Dreamweaver and I defined as a site relative to root. I changed the php virtual to require_once and got the following messages on my site:
Warning: require_once(/CSSMenuWriter/cssmw/menu.php) [function.require-once]: failed to open stream: No such file or directory in C:\vhosts\ on line 81
Fatal error: require_once() [function.require]: Failed opening required '/CSSMenuWriter/cssmw/menu.php' (include_path='.;c:\php\includes\') in C:\vhosts\ on line 81
How do I change the menu.php file include_path?
Jimmy Wu
That would depend on the structure of your site. Basically the path is not pointing to the correct place for the menu.php file.
Is the CSSMenuWriter directory in the same level as the careers.php file?
What does the include look like currently?
trish408999
I figured it out
Dreamweaver was calling for virtual because I defined the site to be relative to the root, when I changed it to require_once, it still didn't work. When I changed the code to include() and pointed it to be relative to the doc root, it finally found the script and ran ok.
Jimmy Wu
Great to hear you were able to sort the cause of the issue out. If you run into any additional issues, feel free to open a new thread.
