Multiple insert not inserting any records
Thread began 6/25/2010 1:28 pm by kmccoll304905 | Last modified 7/01/2010 9:02 am by kmccoll304905 | 774 views | 2 replies |
pinkiguana
I have spend several hours trying to get the multiple insert in dataassist to work, and it never inserts records, does not even redirect to redirect page, just reloads the insert form. I have followed the video and the pdf that provides instructions.
I have also tested with a regular insert of one record, which does work.
Here is the code. Please tell me if there is something here that is making it fail.
<%@LANGUAGE="VBSCRIPT" CODEPAGE="65001"%>
<!--#include file="WA_DataAssist/WA_AppBuilder_VB.asp" -->
<!--#include file="Connections/connNFDT.asp" -->
<% Session("TA_SoNo")="12345678"
Session("TA_RideId")=35 %>
Dim rsQuestions__mmSo
rsQuestions__mmSo = "-1"
If (Session("TA_SoNo") <> "") Then
rsQuestions__mmSo = Session("TA_SoNo")
End If
Dim rsQuestions__mmRideId
rsQuestions__mmRideId = "-1"
If (Session("TA_RideId") <> "") Then
rsQuestions__mmRideId = Session("TA_RideId")
End If
Dim rsQuestions
Dim rsQuestions_cmd
Dim rsQuestions_numRows
Set rsQuestions_cmd = Server.CreateObject ("ADODB.Command")
rsQuestions_cmd.ActiveConnection = MM_connNFDT_STRING
rsQuestions_cmd.CommandText = "SELECT TA_QId, TA_Question, TA_BusMetricDescript, TA_RideId, TA_SO, TA_BusMetricName FROM dbo.View_GetQuestions WHERE TA_SO=? AND TA_RideId=?"
rsQuestions_cmd.Prepared = true
rsQuestions_cmd.Parameters.Append rsQuestions_cmd.CreateParameter("param1", 200, 1, 255, rsQuestions__mmSo) ' adVarChar
rsQuestions_cmd.Parameters.Append rsQuestions_cmd.CreateParameter("param2", 5, 1, -1, rsQuestions__mmRideId) ' adDouble
Set rsQuestions = rsQuestions_cmd.Execute
rsQuestions_numRows = 0
' WA DataAssist Multiple Inserts
if (cStr(Request.Form("btnSubmit")) <> "") then
WA_loopedFields = Array("hRideId", "hSO", "hQId")
WA_connection = MM_connNFDT_STRING
WA_table = "dbo.TA_EvalDetails"
WA_redirectURL = "success.asp"
WA_keepQueryString = true
WA_fieldNamesStr = "TA_RideId|TA_SO|TA_QId"
WA_columnTypesStr = "none,none,NULL|',none,''|none,none,NULL"
WA_insertIfNotBlank = ""
WA_fieldNames = Split(WA_fieldNamesStr,"|")
WA_columns = Split(WA_columnTypesStr,"|")
WA_multipleInsertCounter = 0
while (WA_AB_checkMultiInsertLoopedFieldsExist(WA_loopedFields, WA_multipleInsertCounter))
if (WA_insertIfNotBlank = "" OR WA_AB_checkLoopedFieldsNotBlank(Array(cStr(WA_insertIfNotBlank)), WA_multipleInsertCounter)) then
WA_fieldValuesStr = "" & cStr(WA_AB_getLoopedFieldValue("hRideId", WA_multipleInsertCounter)) & "" & "|" & "" & cStr(WA_AB_getLoopedFieldValue("hSO", WA_multipleInsertCounter)) & "" & "|" & "" & cStr(WA_AB_getLoopedFieldValue("hQId", WA_multipleInsertCounter)) & ""
WA_fieldValues = Split(WA_fieldValuesStr,"|")
insertParamsObj = WA_AB_generateInsertParams(WA_fieldNames, WA_columns, WA_fieldValues, -1)
set MM_editCmd = Server.CreateObject("ADODB.Command")
MM_editCmd.ActiveConnection = WA_connection
MM_editCmd.CommandText = "INSERT INTO " & WA_table & " (" & insertParamsObj(1) & ") VALUES (" & insertParamsObj(2) & ")"
MM_editCmd.Execute()
MM_editCmd.ActiveConnection.Close()
end if
WA_multipleInsertCounter = WA_multipleInsertCounter + 1
wend
if (WA_redirectURL <> "") then
if (WA_keepQueryString AND Request.QueryString <> "" AND Request.QueryString.Count > 0) then
if (inStr(WA_redirectURL,"?") > 0) then
WA_redirectURL = WA_redirectURL & "&"
else
WA_redirectURL = WA_redirectURL & "?"
end if
WA_redirectURL = WA_redirectURL & Request.QueryString
end if
Response.Redirect(WA_redirectURL)
end if
end if
' RepeatSelectionCounter_1 Initialization
Dim RepeatSelectionCounter_1 : RepeatSelectionCounter_1 = 0
Dim RepeatSelectionCounter_1_Iterations : RepeatSelectionCounter_1_Iterations = "25"
Dim RepeatSelectionCounterBasedLooping_1: RepeatSelectionCounterBasedLooping_1 = false
Dim RepeatSelectionCounter_1_IterationsRemaining
If (Not RepeatSelectionCounterBasedLooping_1 AND false) Then
If None__numRows >= 1 Then
If (CInt(None__numRows/RepeatSelectionCounter_1_Iterations) = None__numRows/RepeatSelectionCounter_1_Iterations) Then
None__numRows = CInt(None__numRows/RepeatSelectionCounter_1_Iterations)
Else
None__numRows = CInt(None__numRows/RepeatSelectionCounter_1_Iterations)+1
End If
End If
End IF
<head>
</head>
<body><form name="frmBehaviors">
<p>Question Selection*for Service Order {Session.TA_SoNo} </p>
' RepeatSelectionCounter_1 Begin Loop
RepeatSelectionCounter_1_IterationsRemaining = RepeatSelectionCounter_1_Iterations
While(RepeatSelectionCounter_1_IterationsRemaining)
RepeatSelectionCounter_1_IterationsRemaining = RepeatSelectionCounter_1_IterationsRemaining-1
If(RepeatSelectionCounterBasedLooping_1 OR (Not rsQuestions.EOF AND true) ) Then
<table width="80%" border="1">
<tr>
<td width="30%"><input type="hidden" name="hRideId_mihidden_<%=RepeatSelectionCounter_1%>" id="hRideId_mihidden_<%=RepeatSelectionCounter_1%>" value="1" />
<input name="hQId_<%=RepeatSelectionCounter_1%>" type="hidden" id="hQId_<%=RepeatSelectionCounter_1%>" value="<%=(rsQuestions.Fields.Item("TA_QId").Value)%>" />
<input name="hRideId_<%=RepeatSelectionCounter_1%>" type="hidden" id="hRideId_<%=RepeatSelectionCounter_1%>" value="<%=(rsQuestions.Fields.Item("TA_RideId").Value)%>" />
<input name="hSO_<%=RepeatSelectionCounter_1%>" type="hidden" id="hSO_<%=RepeatSelectionCounter_1%>" value="<%=(rsQuestions.Fields.Item("TA_SO").Value)%>" />
<%=(rsQuestions.Fields.Item("TA_SO").Value)%> -<%=(rsQuestions.Fields.Item("TA_RideId").Value)%></td>
<td width="70%"><p><%=(rsQuestions.Fields.Item("TA_Question").Value)%></p></td>
</tr>
</table>
' RepeatSelectionCounter_1 Begin Alternate Content
Else
<tr>
<td>&nbsp;</td>
<td>&nbsp;</td>
</tr>
' RepeatSelectionCounter_1 End Alternate Content
End If
If(Not RepeatSelectionCounterBasedLooping_1 AND RepeatSelectionCounter_1_IterationsRemaining <> 0 ) Then
If(Not rsQuestions.EOF AND true ) Then rsQuestions.MoveNext
If(rsQuestions.EOF AND CInt(RepeatSelectionCounter_1_Iterations) = -1) THEN RepeatSelectionCounter_1_IterationsRemaining = 0
If(false) Then None__index = None__index+1
End If
RepeatSelectionCounter_1 = RepeatSelectionCounter_1+1
Wend ' RepeatSelectionCounter_1 End Loop
<table width="80%">
<tr>
<td align="center"><label>
<input type="submit" name="btnSubmit" id="btnSubmit" value="Begin Service Evaluation" />
</label></td>
</tr>
</table>
<p>&nbsp;</p>
</form>
</body>
</html>
rsQuestions.Close()
Set rsQuestions = Nothing
please add the page to a zip archive and attach the zip file to your post so I can examine the code in context.
pinkiguana
Temp fix
I resolved this using a temporary fix someone shared of changing certain names of the function used and replacing them with another. It works now, but should not webassist have fixed this issue already? bummer.
