order.php exposed to web
Thread began 6/10/2010 9:06 am by ess408951 | Last modified 6/10/2010 9:13 am by Ray Borduin | 1682 views | 1 replies |
ess408951
A client using your cart extensions is having an intresting issue.
The client was Googling her name and something she had ordered came up.
The code that was associated with the page was;
orders.php?pageNum_rsOrders=1&totalRows_rsOrders=585
Armed with this piece of code I was able to see all of the old orders out on the system.
We deleted the history so the problem went away but I can see this being an issue in
the future.
This version of your extensions we are told is approximately 8 years old. If we
upgrade to you new dynamic suite will this problem be rectified.
The problem isn't with the extension. It is with the implementation. No code is inherently secured. It looks like they ran DataAssist to create a display of orders. The page does just that. If you want to secure that page, you need to provide a login page in order to have the opportunity to add security.
In order to correct this problem you could buy Security Assist and use that wizard to create a login page. Then add security to the administrative orders section that you curently have found is exposed (and to every other page that shouldn't be publicly viewable).
