CSS styles preview in editor
I have a set of CSS styles attached in irite.
Should you be able to see the css styles while editing in irite or just plain text?
Regards
Russell
Regards
Russell
It depends on how you attached them, but it should be possible to have styles you have defined displayed properly in irite when properly attached.
Ray, where could I find out the correct way of attaching the CSS styles.
I have been trying for the last 2 days to get the preview working but to no avail.
I have followed the tutorials and get the styles only showing up once I press the update button.
Regards
Russell
Look at the fckeditor web site: www.fckeditor.com it will have much more in depth discussion on the code underlying iRite.
You can also try posting a support incident at the webassist web site if you think there is a bug or something not working properly in the extension.
